Step 9Display upgrading - getting at the LCD and cable
Opening the lid of your laptop, you'll see eight rubber pads around the screen that cushion it when closed (see first picture). These are stuck on with adhesive and pull off with a little prying. I recommend sticking them all to a single plate or something while you're working, so you don't loose any of them. Behind these pads are more small Philips head screws to remove.
Before separating the lid's plastic, close your laptop and flip it over. There are five screws on the underside, directly beneath the hinge. The middle three are the only ones you need to remove; they hold the hinge cover / power button / light assembly in place. The easiest way to pop it off is by opening the screen, laying it all the way back, then carefully pry as shown in picture two. Once off, you will be able to see where the LCD cable plugs into the motherboard, on the left side.
Now pry gently between the two plastic halves of the lid. Everything clicks together, so it's a little unnerving to force them apart. Mine came apart and went back together without anything breaking, so I know yours can too :) You may have to push the clip release button to get the lid hooks out of the way as the plastic rectangle comes off. Once that's off, you can see the screws holding the LCD in place. Keep track of all these little screws, and take note on how everything comes apart! It's always easier to disassemble than put back together.
A few bits of advice: Always handle the LCD by holding the sides, never the top or by gripping the middle. They are slightly more durable than people think, but why take chances? When purchasing a replacement LCD, choose one without an inverter attached. We don't need (and there is no room) for the extra piece of metal that sticks down below the screen and holds an inverter in place. Our inverter is mounted to the lid itself- so you're looking for just an LCD. Every 15.4" screen I've tried has the side-holes properly spaced for mounting in our Acer. Some have different spacing in the holes on the bottom, but don't stress- the bottom bracket doesn't need to attach to the screen. It will remain stable and sturdy without those two tiny screws.
Add Comment
