3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Acer Extensa Laptop (5620 / T5250) Upgrade & Tweak Guide
Some time ago I posted about installing Windows XP onto my new Acer Extensa 5620-6830 laptop. It's a nice little machine- the price was right, and standard specs aren't bad. But here's some information that could be helpful to anyone with this budget best Buy laptop and wants to get the most bang for their buck!
This guide will cover tips for upgrading, maintenance, plus tweaks and tricks specific for this and other similar model laptops. Learn how to double your battery life, what hardware can be replaced, and if it's smart to do so. In conjunction with my other Instructables, this has some valuable tidbits specific to notebook computers.
Contents:
1.Memory
2.Bluetooth/Wifi
3.CPU (hardware)
4.CPU (software)
5.Misc. Tweaks
6.Final thoughts
Step 1Memory (RAM & Hard Drive)
The Extensa 5620-6830 comes with 1GB of DDR2 memory. That's two sticks of 512MB. This unit technically supports 4GB; 2 x 2GB modules. However, unless you're running a 64-bit operating system (if you have to ask how you'd know, trust me... you're not) then only about 3GB will be usable. There's no fix for this, it's just a fact. All standard 32-bit operating systems are coded this way.
Due to this, I decided to purchase two 1GB modules (making 2GB total). I find that to be plenty sufficient; I've never run out of memory in XP. Keep in mind, Vista will use about 1GB just to boot and run. You'll want to buy 667Mhz modules. There are 800MHz modules out there, but 99% of laptops on the market can't operate at that frequency. You'd be paying extra money for nothing, plus risking incompatibility.
There is an obvious single "hatch" on the bottom of the unit through which we access nearly everything- wifi card, RAM, hard drive, and CPU. You'll need a small philips-head screwdriver to open this. You shouldn't have to apply force once the screws are out, though take note of the plastic tabs along one side.
The stock hard drive is a TOSHIBA MK2035GSS 200GB drive. It runs at 4200RPM, has an 8MB Cache, and uses Perpendicular Magnetic Recording (PMR) combined with Tunnel Magneto-resistive Recording (TMR) Head Technology. All that jargon supposedly means it's roughly as fast as a 5400rpm drive. I find it acceptable. There's faster drives out there, but is it worth wasting the $165 on a 200GB 7200rpm drive just to replace the original 200GB? You'd see a lot more heat, less battery life, and a big chunk out of your pocketbook.
The choice is yours, but I'm waiting for a faster (or equivelent-speed) 320GB drive.
48 comments
1-40 of 48next »
Jan 30, 2012. 6:34 AMmcgj01 says:
I want to install Windows 7 on my Acer 5620, from windows XP. Before I do the upgrade I wanted to upgrade the memory. I have bought two 2gig memory modules, to upgrade from two 1gig modules. Upon startup the message 'Starting Windows' appears, with the scroll bar, then a blank screen, followed by a restart. Inserting one 2gig module and the machine starts up. Install both and it doesn't. I reinstalled the two 1gig modules and everything is fine. Please help!!!!!!
Jan 25, 2012. 10:41 PMaabhilash says:
hi,is it possible upgrade it to 3.0GHz processing speed sir??????
Jan 14, 2012. 12:52 PMcisguy says:
I have an Acer 5620 with the power connector pushed in. I took all the visible screws out, but it wont come apart near the screen which is where the power port that is pushed in is. I looked for a guide on taking it completely apart and didn't find one. I've worked on computers for years, but not normally laptops. If you have any advice on this you can email me at d.dufford@gmail.com. Thanks for your help.
Jun 5, 2011. 10:29 AMkknight2 says:
I upgraded the laptop from vistato windows 7 and the onboard mic doesn't work, the drivers installed correctly, but the mic just isnt working. when i check the volume settings, the mic seems to be maxed out even though there is no input.
I googled some other sites and others have ben having problems with tis as well. Do yo have any solutions?
Oct 20, 2011. 11:46 PMabraxas2 says:
I'm having same problem. Did you ever find a fix ? Anyone ???? I've checked the usual suspects....mute...levels...reinstall driver (at least i think i reinstalled but *&^%$% Microsoft gave the driver an ambiguous "Sound Device" name to suspect driver which could be anything. I presume to be the mic driver).
Jul 12, 2011. 7:58 PMrsrcomputer says:
I too have upgraded from Vista to XP to Windows 7.
Mic works.
BUT the battery went completely downhill. Used to be over 2 hours in XP and within week of installing W7 the battery went to 15 minutes.
Any fix, possible to update battery driver??
Thanks.
Dec 4, 2009. 6:47 AMd9123 says:
I have a acer extensa 5620-6830 with  a 1.5 CPU. If I change the CPU to T8300 will I have to change the bios?
Sep 5, 2011. 11:07 PMrcoover says:
I am using BIOS version 1.35 which works well with the T8300
Sep 5, 2011. 10:54 PMrcoover says:
I've upgraded my T5250 CPU to a T8300. The new chip has an FSB of 800. Checking my memory chips, I find a 2 GB DDR2 chip with a speed of 400 and another 2 GB DDR2 with a speed of 333.
The two mismatched chips seem to work well with each other, but would I have an increase in speed if I replaced the slower chip with a faster one?
Aug 1, 2009. 7:45 PMdavison112 says:
I have this same exact laptop, and ws thiking, does yours overheat ALL THE TIME?!?!?!? and was wondering if it does, did you fix it and how?
Mar 22, 2011. 8:25 AMhjoab says:
Did you need to upgrade the BIOS? where do get the bios upgrade in this case?
Oct 4, 2010. 6:44 PMabraxas2 says:
Can you tell me where I might buy these memory modules ? Any specsI need to watch out for on the modules ? Also, I'd like to back my HD up. I do so with a RW DVD and the backup utility. Problem is this, after it finishes with 1 DVD, I am prompted to insert another one whereupon nothing happens after I close the tray. Any ideas ?
Mar 15, 2010. 6:39 PMpaulvick2002 says:
I installed Rightmark and my temperature dropped by 25 degrees. Thank you!
Also I am thinking about putting Windows 7 on my Acer 5620 as I can for free, do you recommend doing so?
Mar 3, 2010. 11:51 PMloadsasy says:
i have 1 quest pls help..... Intel Core 2 Duo Mobile 2,26 GHz P8400 works on acer extensa 5620?
Feb 15, 2010. 8:54 PMwizzy617 says:
can my 5620 run windows 7
Mar 4, 2010. 1:18 PMwizzy617 says:
and how would i go about doing that
Mar 3, 2010. 11:52 PMloadsasy says:
yap
Jul 14, 2011. 10:24 AMkknight2 says:
Hey i wanna run Mac on my 5620 as well, i have iatkos S3 v2, that i run on another system. What version of Mac do you run on your system?
Mar 15, 2010. 3:53 PMpaulvick2002 says:
Hi Charred, I have the same Acer and now my HD makes noise when it spins. Does that mean it's about to break? I am guessing the answer is yes.
Jan 13, 2010. 10:46 PMkenwg says:
The DC-in jack on my 2 year-old 5620-6830 has failed.  I know it's the jack, because I bought a new AC adapter and it still doesn't work.  Question - Is it likely to be the jack itself, or something worse (the motherboard).  Can I replace the jack or is it integrated into the m-board?  I tried cracking the case, but couldn't get one edge to come up and I didn't want to force it, so I don't know how it's set up.  Assuming the jack can be pulled off and replaced, I don't know how to do it or even if I can get a replacement jack - will have to contact Acer I suppose for the jack.   Anyway, if anyone has some guidance it will be greatly appreciated.
By the way, when I bought this the first thing I did was take it to my local geek shop and to have Vista removed.  They installed XP and it's run perfectly ever since.
Jan 13, 2010. 11:31 PMkenwg says:
Good news - I just did a search online for the jack and found lots of them available on line.  Apparently it just plugs into the motherboard.  So I bought one and it's on the way - now I just need to know how to open the case without breaking it....
Thanks.
Feb 14, 2010. 11:48 PMkenwg says:
Thanks.  I'll look for the service manual.
Jan 6, 2010. 10:15 AMzihuajc says:
hi i have extesna 5620-6830 and i want windows xp but i cant install it somebody can help me
Jan 13, 2010. 11:37 PMkenwg says:
As I understand it from the guy who installed XP on mine, XP can't be installed on a computer built for Vista without an additional driver that isn't included on the XP installation disk.  You have to obtain the driver (I don't know where, but it's probably on the Microsoft website), burn a new XP install disk with the extra driver included, and then use that disk as your install disk.  Mine has worked perfectly now for 2 years so I know it can be done.  Good luck.
Mar 18, 2009. 7:59 PMericsotelo says:
Hey CharredPC, Do you do repair work over the mail? I have this laptop. Acer Extensa 5620 on Vista Home Premium SP1, Intel Core 2 Duo T5550 1.83 GHz 3Gig Mem. No one will downgrade my Laptop to XP Pro for fear that the drivers will not be compatible. What do you charge to do this to my laptop? Thanks, Eric Sotelo esotelo@earthlink.net P.S. How does Leopard run on the Extensa? Can you do that to my laptop too? LOL.. .Thanks. I would rather just pay someone like you who knows how to do this the right way then me screw up my laptop.. Thanks for responding.
Dec 20, 2008. 9:17 AMWendyW says:
I have a question about my laptop Acer Extensa 5620-6830 .Need to know where to purchase a AC/DC adapter so I can use it in the truck as I don't have wireless service yet. Acer stated they didn not make any for this computer but is there a universal one that will work?
Feb 25, 2009. 5:41 PMred-king says:
I found it... unfortunately its quite large... http://www.dcacpowerinverters.com/itemdesc.asp?ic=PW200-12
Feb 25, 2009. 5:38 PMred-king says:
I think there is one. i'll post another reply once i find it.
Dec 5, 2008. 8:24 AMmasterpj says:
well i improved my laptop with ensane result myself. i am laptop expert (no joke) i dont have tutorials, because i either dont have time or well it's not always easy to explain.
Sep 22, 2008. 2:11 AMKhalili says:
Can I upgrade my graphics (Current: X3100) with some external graphic card. Regards.
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:CharredPC
