Acorn Coffee - Modern Take
25,016
257
49
Published
Introduction: Acorn Coffee - Modern Take
About: Chemical Engineering student with interest in Agroindustrial development and nature. International Baccalaureate alumnus with emphasis in Chemistry, to complement my technical knowledge I'm self-taught in Po...
Acorns were a great staple food for Native Americans in the past, the have great medicinal properties and are packed with protein and fiber, on this Ible I will show you how to make Acorn Coffee, I made it at home in a modern way but it can be perfectly made in the bush, primitively, enjoy and as always leave feedback.
PS: I was saving up Acorns to make flour for cookies but didn't have as many (only a handful) so that's why I decided to make some coffee.
Step 1: Ingredients and Tools
For your ingredients and tools it´s really simple, I use modern tools but you can do it as our ancestors did it in the past.
Ingredients
  • Acorns (Who wants Acorn Coffee without these)
  • Water (It´s a beverage right?)
Tools
  • Kettle or boiling water mechanism.
  • Hammer, could be substituted by rocks.
  • Coffee grinder, also rocks are a substitute.
  • Filtering system, I used a flannel coffee filter.
  • Frying pan or any method to roast.
  • Sieve.
  • Spoon.
Step 2: Gathering and Making Acorn Meal
When picking your acorns go for big and healthy ones, go for the brown ones, green ones are no good, any cracked ones or acorns with holes discard them. Crack your acorns and de-meat them, go from a bright yellow to a pale brown, acorns with black spots discard them.
To make your meal just pulse the meat in your grinder until a fine flour forms, sieve and re pulse if necessary.
Step 3: Roasting
I didn't really take enough pictures of this process because it happened so quickly specially with the small amount of acorn meal I had.
To roast use a your pan and use medium to high heat, stirring constantly with a metal spoon to avoid any moisture from wooden implements to transfer, acorns will start turning a dark yellow to brown and when starting to go to a dark brown turn of the heat to continue roasting on the hot pan, stir rapidly to avoid burning, a great smell will come of your creation.
Step 4: Brewing and Final Product
To brew, grab some boiling water and your filtering system, you can make coffee bags with filters also, add 1 1/2 spoons of coffee per cup of water for a great taste, add sweetener if needed, mine was just an experiment because of the little acorns I had and tasted great, but hopefully I will find more soon and publish more photos. Thanks for reading up to here.
Enjoy your cup of Acorn Coffee!
PS: If I gather enough I could make some flour for cookies!
    • BBQ Showdown Challenge
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
    49 Discussions
    Those sort of pages where the base of my Instructable, Thank you!
    Here is a link all about acorns. Leaching, choosing etc along with a little trivia. Any questions this will answer them.
    http://www.eattheweeds.com/acorns-the-inside-story/
    Great 'ible. A small detail: Boiling the acorns in the shell for 20 minutes helps with the tannin issue, and also makes the acorns easier to open. Then just grind & air-dry the acorn meal in a warm place before roasting. 3 table spoons makes a great cuppa.
    Be careful when eating acorns, some species of oak the acorns can be eaten raw while other species need processing to remove the harmful chemicals (tannins). The process for removing the tannins from acorns is to soak or boil in water, this leaches the tannins into the water that is then discarded (sounds a lot like making coffee). I can find no information on roasting and its effectiveness on removing tannins.
    For anyone eating any wild edible I would highly suggest you do some research before eating anything.
    Listen to Benjamin. I eat acorns-meal and flour as well as rolled in cinnamon sugar and roasted but virtually all acorns contain more tannins than humans can handle. Find a good book on the subject-there are dozens. Use a search engine. NPR did a great article on this within the last couple of years. Always research. Always.
    Today I went to a park and there were oak trees (not suure which kind) but there were a bunch of big black acorns so I picked a few and took them home. When I boiled them though, they had gooey black insides so I threw them out. Does anyy one know why that is? My guess is that they've been on the ground for a long time.
    In Houston,Texas I've found a Humongous kind of Acorns? they are the size os Walnuts but,Brown not White Acorn. Are these Species Safe to use as "A Beverage and Flour to make Cookies?
    Thanks for the Info?
    How about the Squirels, Why they don't Die by Eating Acorns??
    Says the caveman :)
    Me too, I hope I'm not too late to get some good ones.
    Actually you're terribly wrong, people have been making coffee out of acorns for hundreds of years!! For example in some parts of Europe coffee beans were a big rarity(northern and eastern Europe) so people used what they had by their hands and made coffee out of acorns, it's very delicious, healthy and rich with vitamins!!
    So Please, don't write dumb things if you don't know anything about it!!
    I do know what I'm talking about an MOST acorns are toxic unless leeched of their harmful tannins. Which basically means soaking in water or boiling and straining through a sieve. Which would effectively make it pretty impossible to make a tea out of. And if you skip the leeching process you're gonna poison yourself. And writing this article up without giving that detailed information is irresponsible. Now STFU and stop giving people half information. It gets people killed.
    Tell me, have you made it at least once? Have you drank it? With right treatment they are edible and can be made into coffee.... I believe expierience is more valuable than pure information gathered from internet. There's no need to show off how "smart" you are!!
    Guns get people killed not coffee made out of 5 acorns!
    MOST acorns as you said, I'm alright and I tried it, it was just a test as mentioned so I could add more information to my Ible and also your bad language is not nice.
    It tastes great with milk and sugar. Thanks for the Idea
