Remove these ads by
Signing UpStep 1: Materials
-1 9v Hobby Motor
- Screws
-1 Plastic Wheel from Parallax item #721-00001
-1 HomeWork Board from Parallax item #555-28188
-1 Sound Impact Sensor from Parallax item #29132
-1 Solderless Breadboard from Parallax item #700-00078
-1 H-Bridge from Parallax item #603-00019
-2 Alligator Clips from Radioshack item #270-378
-Jumper wires from Parallax item #800-00016
-Spool of Wire from Home Depot (For wiring the sensor through the door frame and the wiring too long for the jumper wires.)
-Basic Stamp Editor v2.5.3
-2 L Brackets from any hardware store.
We also used various sizes of wood, but that is for our model door.
The motor listed above meant for our scaled down model door and will not likely work on the bigger or heavier doors, but may work on normal doors that are light weight. For the bigger and heavier doors you might want to use a motor with more power and maybe a bigger wheel.
Visit Our Store »
Go Pro Today »
Now, I have the opposite problem and thought your team may have hit upon or come across a solution when designing this door project.
I have a small wire "door" that I want to open thirty minutes (or so - 15-30 would do) after it is shut/closed.
The circuit should be battery-powered. The Battery(ies) should not be connected to the circuit unless the door is shut and the timer functioning. That is, when the door latch is released and the door springs open, the power should be removed from the circuit.
I'm not an electronics guy but can bread board a circuit using discreet components and can solder things together if they're not too small!
Basically I need a circuit that can run off six or eight AA cells that will energize a solenoid with all available voltage fifteen minutes or so after the circuit's "Start Countdown" button is pressed. Know of a source for such a circuit diagram?
Wow. A blast from the past.
I'll relate this just to show that there's more than one way to skin a cat (what a terrible expression!)
About 1970, I built a sound-triggered electric door opener-closer for my bedroom door. My approach was somewhat different as it depended on what a 13 year old could scrounge. The motor was a sealed-gearbox, very geared-down shaded-pole unit that came from a junked Timex watch display. The output shaft speed was only a few RPM.
I used a bored out rubber stopper from the school chemistry lab to slip over the shaft, then using steel 2-part epoxy I attached an aluminum flat bar arm about 6 inches long to the flat top of the stopper. A second slightly longer piece of flat bar pivoted on a bolt with plastic washers (margarine container lid cutouts) at the end of the first arm. The rubber stopper acted as both a "slipping clutch" in case the door jammed, and as a shock absorber as the door hit the limit switches at each end of its travel.
The far end of the second pivot arm attached to a pivot bracket on the backside of the door; the motor was attached to the wall with L brackets. The motor only turned in one direction, so the bend-in-the-middle bell-crank linkage was needed to give both opening and closing motion.
Limit switches at each end of the "open" and "closed" position were momentary contact pushbuttons from Radio Shack. The motor control system was a series of relays that would operate the motor, stop it when a limit switch was reached, then (and this was the hard part) self-reset. Most of the relays came from the junk pile at the engineering department of a nearby university - no two the same. The voice/sound control was provided by a microphone and transistor on/off switch ordered from Edmund Scientific. That was the only "electronic" component, everything else was electromechanical.
It took a bit of fiddling to get the bellcrank arm lengths right so that the door would fully close or fully open. The relay power supply - 12-14 volts - came from an audio transformer that had been inside an old hi-fi set. I hooked it up backwards to 120 VAC and it gave (by pure luck) about the right voltage to operate the relay coils. Being ignorant, I didn't know you weren't supposed to do that. :-)
I remember that making the logic circuit completely automatic using only relays and momentary switches was an absolute stinker of a problem - I worked on it for months. Eventually, it all worked, much to everyone's amazement, including my parents.
Once everything was in place, it operated for the next seven years without any further service, or having the power turned on or off. The door would open on a loud noise (clap or loud word), and stop in the open position. A second microphone in parallel, inside the bedroom, would actuate the circuit again to close the door. I added a pair of pushbuttons on the bedside table which triggered the circuit the same way. It was amazingly quiet and reliable, built completely from junk, and except for the mail-order "sound switch", a whole set of logic circuits made from electromechanical parts.
I was about 13 - I built it because nobody told me it impossible (some did later, except I'd built it and proved them wrong), and I wanted an electric door closer on my bedroom. It was inspired by Star Trek, I think. I later went on to study Electrical Engineering, and spent a good many years in grad school and then as a full-time researcher - my "tuition" in homebrewing paid off, I guess.
Nowadays, the whole thing could be controlled with a couple of op-amps and a MOSFET, or an Arduino. The bell-crank motor mechanism was a good deal more compact than what you've designed (although yours is an elegant design), and it didn't require a curved track - it just tucked in next to the door hinge. The electromechanical logic circuits that ran it all fit in a wooden case about the size of a shoebox, with vents for cooling. All the random small metal parts were also from junk - brackets, bolts, etc.
The only money expended was for the Edmund Scientific sound switch - about $5.00 - and the cost of the momentary contact switches - about 99 cents a pair. A small square of rubber weatherstripping glued to the door where the limit switches hit softened the impact on the switches.
I had originally tried magnetic reed switches and magnets - I found a PC board with about 30 reed switches on it for $1 at the army surplus store, but they were unreliable - didn't have the superior magnets available now. I also forgot to mention that I removed the latch bolt from the doorknob set - leaving the knobs, but no latch.
Thanks for the interesting Instructable, and for the trip down memory lane.
The sensor part could easily interface to the catch to trigger it's release.
How doors open and close in a space being used by the public is something to be very careful about. Especially when you're talking about using motors to force the movement. You don't want to have someone that's unfamiliar with the setup to suddenly get injured because of it.
Not that it isn't a cool idea, it is.
I love it - as soon as a noisy class approaches my room, the door will slam in their face - no entry until you are calm and quiet!
