3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Acoustic Vulcan lyre
The Vulcan Lyre, my ultimate testiment to nerdyness. The device one uses when you need to rock out with your Spock out. I must express my gratitude to Michelle my wonderful wife for her help with this project. That she works in a wood shop and knows her way around it has been extremely helpful.
I designed this to be as close in shape to the classic prop from Star Trek as I could, but to be acoustic rather than electric.
EDIT: Here's an MP3 of me playing this lyre
http://secretagent036.googlepages.com/v-lyre-1.mp3
EDIT 2: By popular demand I have added a schematic image with some dimensions. I didn't measure much of anything when I built it so i had to go measure the actual article to get these numbers.
Step 1Basic Body
Basic Body
First I designed my lyre shape in a vector graphics program. While adobe illustrator would have made more sense I did it with 3d Studio Max, just cause I like how it handles curves. Technically we can shorten this step to "Draw your lyre".
Then I printed the whole thing out. My printer isn't any bigger than yours, so I had to print it out in sections and then tape it all together. Next I cut out the whole shape, taped it to a big piece of 3/4 inch plywood and cut the sucker out. If you are a better free hand drawer than me you could probably skip most of that and just draw on the plywood. I was trying to get mine as close in shape to Spock's as possible so I was a bit anal.
Next I made a copy of it with some more plywood, then glued the halves together with some clamps.
Oh, uh, see that little area at the bottom that isn't cut out? Yeah, that's important, it does stuff. Namely it gives to something to screw the tail piece to.
85 comments
1-40 of 85next »
Jun 11, 2011. 4:56 PMHitman227 says:
Ha ha cool, good job... "Live long and prosper"- you know who.
Jun 11, 2009. 2:09 AMDoctor_Duquesne says:
My last comment (probably). Instead of taping pieces of the harp template together, it's a lot easier to go to a Kinko's and have the whole thing Xeroxed on one of the big large format copy machines. An 8 x 11 inch page can be easily blown up thee or four hundred times-- even much more-- to make a "life size" copy of the template. This costs about four or five bucks for a 24 x 36 inch copy. To make the neck template for my lyre, I had to blow up the plans 630 per cent to get a 24" neck. It takes a little work (and a tape measure) to get it blown up to the exact size wanted, but you only have to pay for the copies you keep; the ones that came out too small or too large can be thrown away.
Jun 1, 2011. 1:37 AMDoctor_Duquesne says:
It took a long time with no accurate plans,but I think I got it all sussed out now after getting the neck too big for only 19 strings.
The first one is solid walnut with mahogany plywood on the top, the other is plain plywood. I think I'll settle on using ash because it's strong and cheap (but I wish a little less heavy. Almost finished now. When I finally get it done, it will be a thing of beauty.
Jun 2, 2011. 12:37 AMDoctor_Duquesne says:
Thank you, sir. :-)
Jan 24, 2010. 6:41 AMLittleRedDragon2386 says:
I lov ethe idea of making your own instruments XD was wondering where you got the zither pins though ^_^ I could do with some myself for my project XD and if I'm allowed may I alter the instructions for my own kind of instrument? Am planning to make my own Guzheng and was kinda getting annoyed when I couldn't find any instructions for them :(
Am really glad you made the Vulcan Lyre as it seemed interesting and looks simple enough for me to make a Guzheng via these simple instructions XD
Hope you'll let me alter the instructions so I can make my own Guzheng ^_^ it much cheaper than buying a full Guzheng made in some other country ((the price for the cheapest Guzhengs are way too high even by British standards!!!))
Keep it up! You're doing a great job  XD  XD  XD
Jun 2, 2011. 12:23 AMDoctor_Duquesne says:
I don't remember where I got mine, but there's a music supply place that not only sells packages of 100 chrome zither pins for real cheap, but also really cool looking black zither pins.
The Star Trek Tech Manual says the Vulcan harp uses black erandanite pins but since those are a little hard to get here on earth, I use black zither pins instead. They look great especially with colored nylon harp strings and up against a brass fret bar. The fret bar can also be black plastic, and those black zither pins make a good combination.
Anyway, Google "zither pins" and you shouldn't have much trouble finding a supplir of either kind of pins.
'Doc
May 14, 2011. 10:05 PMDaftehh says:
Well, here's mine.
At some point I thought it would be smart to have 19 strings, but that left me with little space between the strings to pluck.
Also, I put the pin holes on the wrong side, so I have an awkward position playing it.
But it turned out pretty good. Thanks for the template.
Nov 19, 2010. 5:19 AMDoctor_Duquesne says:
Your 2nd lyre is a beautiful instrument. Looking at the photo, it almost looks like it's made from one piece; almost like guitar construction. I can see how a top panel can be placed to make it look that way, but it also looks like you covered the neck too?
I've been making mine out of walnut, which is costly, so I am always looking for a better way. Would you say how you got the second lyre to look so elegant?
May 26, 2010. 8:35 AMieatdick says:
im not much of a star trek fan but did want a lyre harp so i decided to make one in my woodtech class. this one has a little diferent shape but i used the same basic steps when planin how to do mine. i use solid mohogany and routerd out the inside instead of going all the way through. then i put a thin peice of oak flosh with the top over the hole. its not as loud as an acustic guitar but it is a good deal louder than an unamped elictric guitar is. i think its sweet thanks for the idea.
Jun 3, 2009. 5:27 AMrimar2000 says:
Good work, nice instrument. But, isn't weak the mast for the cords? I would add a (key, derrick, strut, stanchion, pitprop, prop, brace, puncheon, shore. (pardon, I don't speak Emglish)), although that would alter the aesthetic.
Apr 27, 2010. 9:24 PMDoctor_Duquesne says:
I've watched The Way To Eden a couple dozen times now as that episode has the best view of the harp-- you can even see the [Vulcan] speaker on the back if you have a good freeze frame and a quick finger on the button.
From this show it looks like the harp is about 1-1/2 to 2 inches thick, which is a reasonable thickness for an instrument of that type. The Star Trek Technical Manual is deceptive in many ways, so I rely on that show and he photos from it for some sense of size. But, hey; there are about three diferent versions of the harp seen on the show so it only matters to anal people like me who want it down to 100 per cent plus accuracy heh heh.  <g>
Dec 24, 2009. 9:06 AMButterface67 says:
I loved your instructable when I say it, and I and thought, "I'll make one for my wife this Christmas."  She's not much of a Star Trek fan, so I won't tell her of its Vulcan heritage - it looks like a cool exotic instrument and that's enough.
I had to make it at work on my lunch times between Thanksgiving and Christmas.  It was very easy to make and it sounds great.  Nice work to make your instructions easy to understand.
Jul 29, 2009. 2:50 PMmarkus2102 says:
where did u get the space suit???? XD great ible to thanks
Jul 29, 2009. 1:09 PMAztof says:
great! It looks just like the one that Spock plays in "Amok Time" 5/5
Jul 8, 2009. 9:12 PMcorey_caffeine says:
this is really nice. could you possibly give some details on how to play?
Jun 23, 2009. 6:24 PMNynaeve says:
Not sure if I already said this, but if not, it bears repeating: A) Absolutely awesome instrument! Looks better than the original electric ones, imo. B) Absolutely fantastic job both on the construction and the 'ible. C) Thanks so much for posting the mp3, and your playing is great. :) D) You and your wife are awesome.
Jun 22, 2009. 11:00 PMPunkguyta says:
To be honest, when I first seen the thumbnail for the instructable, I thought he was building some kind of instrument out of some rubber diaphragm or a hot water bottle or something, just the shape and color that it was from afar.
Jun 18, 2009. 12:21 PMREA says:
the guy playing it in the picture looks a little like Gordon Freeman.
Jun 19, 2009. 1:09 PMREA says:
your welcome
Jun 18, 2009. 1:24 PMBriterican says:
Although nerdy, I gotta say this is really sweet and creative. Great Job!
Jun 4, 2009. 2:26 PMthepelton says:
This is so "Big Bang Theory".
Jun 11, 2009. 5:19 AMnaruto the ninja13 says:
i love that show!!!!!!!!
Jun 5, 2009. 3:32 PMereynaud says:
How long and how wide is the lyre?
Jun 10, 2009. 6:36 PMDoctor_Duquesne says:
The guy who made the original plans was a bad draftsman; he should've made dimension lines, but I suspect too that maybe he was trying to make money by having you buy two or three of his booklets-- you'd have to, in order to be able to cut out all of those different template pieces. Anyway, after a lot of trial and error and hard work I finally got the one I'm working on down to 47" long x 17" wide with the neck being the longest piece at about 24" long. This is like the version Spock plays in The Way To Eden episode with the space hippies. The one Uhura plays has a shorter neck and a wider body.
Jun 10, 2009. 8:42 PMDoctor_Duquesne says:
At the time, I didn't have a good template and the harp came out {way} too big, but what I used was a 2 foot x 4foot wood panel I got from some company. I had to glue two of them together since 3/4 inch was their biggest thickness, but the results were just as good as plywood but without having to worry about sprucing it up-- and just as good as solid wood but without having to make individual pieces. I don't know if any companies make these wood panels any more in 2 x 4 foot sizes, but if any are available, it's really worth the cost to use pre-cut panels-- especially in light weight woods like hickory, birch, walnut, etc.
Jun 9, 2009. 8:51 PMereynaud says:
Hi: is there a chance that you would post a pdf file of the template?
1-40 of 85next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:agent036(Making Noise)
Hi, my name is Jason, and I'm am artist. That doesn't mean I get payed to do art, though I have, I just am. The medium isn't important, the mind set is. I love to learn new things and attempt to expre...
more »
