3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Acrylic Flaming Sword
I had submitted an instructible on this before but it did not present very well so here is the revision.
My Daughter challenged me for a prop for a character she was cosplaying as in San Japan :3 in San Antonio, Texas 2010.  She was cosplaying as Shana who is armed with a flaming Katana.  I didn't want to make a typical paper mache or wooden prop with flames painted on and an actual flaming prop was out of the question.  LED lights then came to mind but the idea of resistors and imbedding the lights into  the prop without them looking like Christmas lights was leaving a bad taste in my mouth.  An idea using plexiglass, acrylics, and my strobe flashlight then came to mind. So from challenge to brain storming to blue print to construction I present to you my instructible.
Step 1Materials
Materials
These are the materials you will need:
1) A sheet of plexi glass 1/4 inch thick and 3 feet long.  You can get away with a using a shorter peice (cheaper this way) and cutting peices you canconnect together to make 3 feet, but this weakens the integrity of the blade.
2) Clear transparent acrylic plates (orange, yellow, and/or red). The flatter the plates the better.  These will be used to mimic the shape of flames. I shopped the local dollar stores and found what I needed, otherwise you can find these at Walmart.
3) 1 inch PVC pipe and a cap. You will need about 9-12 inches of pipe, depending on the size of your flash light.
4) I have a Mag Lite XL100, costs about $35.  If you have a Mini Mag you can buy their IQ switch and LED light conversion to turn it into a strobe flashlight (this would be cheaper even if you bought a brand new Mini Mag).
5) PVC pipe cutter or hacksaw
6) Coping saw or scroll saw
7) Small spring clams
8) Liquid Nail Perfect Glue 2 or similar glue (Super glue does not work very well)
9) Dremel (if you have one) is always handy  in any project
3 comments
Sep 15, 2011. 7:56 PMnerd12 says:
video + Closeup please
Aug 18, 2011. 9:37 AMluperion says:
very nice! i work with this material all the time. very nice idea, and i applaude you for helping out your daughter with her cosplay! :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Dadime
