Stuff used:
- Acrylic Guitar
- Blue LEDs from ASDA (�3.50)
- A Rocker Switch salvaged from a broken laptop power supply
- A bunch of Icicle sticks which were saved up (I knew they might come in handy)
- Soldering iron
- A Drill
- A steel rule
- Screwdrivers
- My brother's arm. I didn't have a set of helping hands at this point
This took about 30minutes and (I think) looks pretty awesome
EDIT: If you mess up your guitar, It's not my fault, it's your own, so please don't try to sue me or anything =D
Remove these ads by
Signing UpStep 1Making Battery Space
Then I found a bunch of old icicle sticks lying around and jammed them between the bridge and the body of the guitar and removed the springs. this left a perfect space for the battery compartment.
Obviously, since the switch is on the compartment, this was going to be awkward for switching the lights on/off. So the switch was left on and another switch was inserted in the wiring.
http://www.google.ca/imgres?q=dr+strings&start=261&hl=en&sa=X&biw=1024&bih=625&tbm=isch&prmd=imvns&tbnid=zyNsQPuIX6wGRM:&imgrefurl=http://kickport.com/blog/2012/01/the-hottest-new-gear-from-day-one-of-namm-along-with-the-kickport/&docid=gip8CrCB-hm1uM&imgurl=http://www.americansongwriter.com/wp-content/uploads/2012/01/100_2441.jpg&w=1920&h=2560&ei=NIi2T6DbL7GM6QHTxLGACw&zoom=1&iact=rc&dur=421&sig=110560063112201783142&page=13&tbnh=141&tbnw=120&ndsp=21&ved=1t:429,r:18,s:261,i:187&tx=103&ty=97
they rock \m/
The string of LEDs I bought had a battery pack connected to it :)
Thanks so much
Also if you sand sertant parts of the acrylic or drill holes in it those willlight up brighter, look into it
It'd also be awesome to make it a strobe light! haha
Very cool.
a reasonable answer for a rhetorical question =) lol
But it should be similar.
Bear in mind, if you mess it up completely, It's not my fault =D
ALMOST as good as mine :P
http://www.instructables.com/id/The_Plastic_Rainbow_Instrument_of_Sonic_Mayhem_P/
I would enter it for this contest but blah blah only published since start of yadda yadda. Its only some daft monkey lights anyway..
Anyway, nice instructibly. Hope to see more.
Thanks anyway =]
