Introduction: Acrylic LED Pendant
For this years Helle-Koepfe workshop we simplified the last years nametags.
Again we use the lasercutter to work with 2mm acrylic. A 3mm LED and a 2032 coin cell is used to enlight the pendant, and a simple string is used to wear it.
Step 1: Production
Making the pendant is pretty streightforward: Each kid could write their name on the pendant in the svg file and chose a motive, which is then cutted out with the laser, motive and name are either engraved or marked. Thereafter, the backside protection foil is removed and a led inserted into the small hole.
The legs of the LED are then bend to reduce their length and a coin cell inserted into the big hole. A strip of transparent adhesive tape fixates the legs on the battery and guarantees contact.
A piece of string through the upper holes completes the pendant.
Done and Enjoy!
4 Comments
What laser settings did you use for engraving the acrylic to that nice frosty finish?
Use cast acrylic (compared to extruded) to get a frosty white finish. I use 81% speed and 40% power with my 45watt engraver.
I'm not really sure what to use with a different laser cutter, i just used "engrave" in the VisiCut control software with 100% power and 100% speed for the laser cutter, the frosty finish happens i think by chance through the pulsation of the laser and the resulting uneven surface
Yay!
