The arm protectors have two functions: one is to protect the arm from string slaps, and the other is to keep clothes out of the way of the string. The smooth plastic also may mean that if the string goes on the protector, it won't distort the shot extremely (though it will distort it significantly).
These are usually made of leather, but I don't have any scrap leather.
Remove these ads by
Signing UpStep 1: Cutting acrylic
You can cut acrylic sheet by scoring deeply (a couple of passes may be needed) with box cutters, and then breaking (while wearing safety goggles, of course). Then you can smooth the corners and the edges with sandpaper, a file or (in my case) a sanding drum on a rotary tool or drill. As always, when sanding plastic (and other things) wear breathing protection.
Visit Our Store »
Go Pro Today »
The riser handle is gripped not at the palm but at the junction of thumb pad and fore finger.
Doing this you will feel like the bow will "jump" out of your hand this only is achieved by proper hand grip, to keep the bow from "jumping" out of your hands a bow sling can be used
Your arm guard can be used though to keep camo clothing from touching your string on release.
I do keep the bow as described, with some other fingers loosely circling the grip to perform the sling function.
If the elbow is slightly bent, won't that lead to a draw-length inconsistency, unless of course a clicker or other draw check is used, since it's hard to bend at the same angle each time?
