Action Geometry From Trash
204
Posted in CraftArt
Introduction: Action Geometry From Trash
About: I'm an applied physicist by training(phd Yale 2006, BA Berkeley 1998, math and physics), and have done physics research in the federal government and product development in the private sector, starting two o...
This shows how to use trash-only geometric fabrication to make what I call my "C1" construction, the first construction of Action Geometry, the system I use as the basis to build all things. In the end we make the three C1 constructions which are documented here:
These are the building blocks from which I build the C2 construction, which is the cardboard Platonic Solids. And with those I can build up to C3, which is the three dimensional construction geometry documented here:
The problem with the previously published version of the C1 shape constructions is that you need a compass, and those are annoying to find, and generally cost money. Also the ruler using English units is not ideal. So how to I build up the tools of classical geometry from trash in a way that actually works but doesn't need some capitalist nonsense like a compass or rely on imperialist units? By using the following tools:
  • clear plastic drink lid
  • wood stir stick or other straight object you can write on
  • pen
  • paper
  • my hand, either hand, or someone else's hand
Step 1: Get Basic Unit From Anatomical Measures
I use the length of my ring finger, the third finger over from the thumb, between the middle and pinkie fingers. I mark on the stick what that length is. I could pick any finger of course, but by choosing a body part and sticking with it I can repeatably build technology from this with some consistency internal to my own technical systems.
Step 2: Construct Triangle C1
Follow the images and look up the compass-and-straightedge version I have up here, as well as the trash construction I posted here. I'll be adding more content here as time goes on as well.
Step 3: Construct Square C1
Same as triangle, but compare to this instead of triangle.
Step 4: Construct Pentagon C1
Now I follow the Golden Triangle construction here.
At this point you can cut out, laminate, paste to cardboard, copy, duplicate and spread.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
