Remove these ads by
Signing UpStep 1: Needed materials and Basic Idea
Activated Carbon
Glue
Window screen
pantyhose
Modeler's plywood
Basswood or balsa
12 volt AC/DC converter
If you have enough modeler's plywood, then you can make the frame out of that, but to save money, I chose to glue my frame together with some balsa wood I had. I had everything but the activated carbon, which you can purchase at pet stores, already at my house.
The purifier works by drawing air through the carbon and forcing it out through the top. The picture below is a cutaway view. The carbon surrounds the purifier on four walls with the fan on the top. The large surface area allows the air to pass through slowly which cleans the air much better.
Visit Our Store »
Go Pro Today »
You can buy these dryer sheets that are designed to give you clothes a nice smell, you should buy a box of them and tape them to the window screen.
you can buy surgical masks that have a type of active carbon material layered between two needle punched non-woven fabric they are great.
the needle punched fabric filters out dust
and the active carbon material can filter out bad smells
the surgical mask can also filter out viruses and bacteria so it works like a hepa filter! all you have to do is cut of the ear loops and the sides so the pleats open up then you can use it. it costs like £3.00 for 50 masks so it is so cheap and they last for about 1 month.
I have put my fingers across a 12v 5a source and i didnt feel anything. You need at least 40 volts with moist skin to even feel anything.
Ampere = Volts/Resistance, in this case 12v / 1000r (resistance of the skin)
Therefore Wally_Z's arguments are invalid.
Some people need to know what they are talking about, SERIOUSLY!!!!
http://www.goldmine-elec-products.com/prodinfo.asp?number=G1783
Do you think this generator could be used in an ion fan build of some kind.
But Ideally if someone was concerned about really purifying the air the DIY method, one would use three filters.
Some reusable/washable filter Than a Charcoal filter for smell and finally a hepa certified filter for biotic and allergenic issues.
The reusable/washable filter would catch big dust and hair that can significantly shorten the lifespan of you're Charcoal and Hepa filters.
The Charcoal filter was covered in the comments and article so I wont bother but link you here. The carbon specifically used in this ible was from the looks of it classified as GAC Granular Activated Charcoal.
Finally the HEPA Certified Filter will get rid of airborn pathogens and the rest of the superfine dust.
Airflow, Purity, Efficiency,
Its kind of a pick two scenario, you can have any of these two options but you sacrifice the third.
