3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Activated Carbon Air Filter
Step 2Make the Frame
Make the Frame
This part is critical since it is what keeps your filter from falling apart, so cut and glue well. For the edges of the walls, I used 1/4x1/4 inch strip of balsa. To support the middle, I used 1/8x1/4 inch strip of balsa. Next, make 4 of both the inside and outside walls. You may need to cut some small squares of paper to stick in the corners for extra support.
After the walls dry, lay the window screen out on wax paper. Apply a thin strip of glue to one side of each wall and place onto the window screen. The wax paper will keep the glue, which will run through the screen, from sticking to your table.
After the glue dries, cut each wall away from the sheet of window screen.
Next, cut a 45 degree angle in two sides of the wall so that the four outside and four inside walls can be joined to each other. Make sure that the window screen is on the outside of the square. In the end, you should have two squares with four walls covered and two left open (for the top and bottom of the filter).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Hatty
