3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adapter for air mattress pump nozzle
Problem: The small nozzles which came with a foot-powered bellows pump did not fit the large inlet holes of my air mattresses. The largest nozzle was about 0.5" diameter (12mm). The inlet in my air mattresses is 1.25" (31mm).
Solution: I fabricated an adapter from junk parts (a plastic funnel, bicycle inner tube, and some copper wire). Adapter works great. It stays well inserted while foot-pumping. Inflates mattresses fast. Project consumed 45 minutes.
Parts and Procedure: See subsequent pages.
Side comments:
- My original plan was to slide the inner tube over the large end of the funnel. Too difficult with the size tube on hand. So I routed it inside as shown.
- Even then, sliding the tube over the small end of the funnel was difficult. Dipping in water helped. Next time, I would use a larger tube.
- Shrink-wrap tubing over the copper wire ends would be nice. Remember to slide it on the hose beforehand. (I forgot, as usual.)
Enjoy easy pumping with 'yer foot.
Step 1Parts
Parts
Find the following parts in your scrap heap:
- A section of long-neck plastic funnel. Mine was intended for changing auto motor oil.
- A bicycle inner tube. Use a section without patches.
- Some small solid copper wire. I used insulated telephone wire, about 24awg.
Optional:
- Large diameter shrink wrap tubing. (I did not think of this soon enough.)
1 comment
Apr 3, 2009. 1:00 AMBobblob says:
Two major design goals are keeping things simple and effect. Looks like you have done both. Unlike many Instructables, your pictures are clear and informative. Well done, thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:a.doovz
