Step 5Prepare the Wires for Soldering
These wires will probably be fine gage, multi-strand and lacquer-insulated. To remove the insulation on these wires, pass the end of each wire through molten solder on the soldering iron tip. Do this a few times for each wire, discarding the solder each time. This will burn off and remove the lacquer and tin the multi-strand conductors.
Before soldering any wires together, you might want to clip them together and test that the system works.
Add Comment
