Introduction: Add 3D Effects to Your Printed Photos
In this project I'll show you how to add 3D effects to your framed photos. There are a number of websites available that explain this technique but I hope to provide you with a more detailed approach, making the job easy. In short what you'll be doing is cutting portions out of multiple images of the same photo, from the background to the foreground, slowly building up a layered 3D effect.
Step 1: Selecting the Right Photo
Not all photos make for good 3D effects. I found the best images are those that have a good depth of field and defined layer that could be easily cut-out for your project. The image used here has both of those elements and is formatted for 4" x 6" & 5" x 7" photo frames. It's a stunning photo of St. Maria's Cathedral in Burgos, Spain. One of the major cities along the pilgrim route of the Camino De Santiago Compostela. If you'd like to view or download this photo for a test project; visit thecamino.com.au and follow the link to their Photo Gallery.
Step 2: Tools for the Job
To create your very own 3D Printed Photo, you'll need;
1. Multiple printed copies of the same photo; usually no more than 6 to 8 copies.
2. A shape Stanley Knife of Craft Blade.
3. A Cutting Board or Thick Phone Book.
4. Some Scotch Mounting Tape or Double Sided Tape
5. A Ruler, and
6. A suitable Photo Frame.
Step 3: Multiple Copies of the Same Photo
Now that you've selected the photo you want to use, you'll need to make multiple copies of the same photo. If you look at the photo, you'll note there are around 6-8 main levels if depth; The path in front of the cathedral as the first level, the front balcony of the cathedral as the second, and so on. We'll explain how to cut out the various levels in the next step.
Step 4: Cutting Out
When you're cutting out your layers, I find it easier to work from the foreground layers (objects of the photo closer to you), to the background layers (objects in the background). In the case of this photo, I started by cutting out the walk-way and people in front of the photo as one layer. Next I cut out the first section of the stairs and the front balcony of the cathedral, including the walk-way as the second layer, and so on.
Step 5: Sticking It All Together
Once you've cut out your various layers, you can start sticking it all together using your Mounting Tape; this time working your way from the background layers you cut out, until your picture is complete.
Step 6: Adding to That 3D Effect and Frame
Aside from layering your photo, you'll notice that sections of the photo appears to be suspended outside the picture frame border. This adds to the effect that the picture and captures the eye when you look at the picture. Now you can mount you photo in your favorite photo frame and your good to go.
