3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Add Diode-Clipping Distortion to your Guitar Amp
Here's a relatively simple way to add some "bite" to your old guitar amplifier.
Amplifier overdrive and distortion is usually achieved by signal clipping--pushing the gain until the signal peaks are chopped off. "Real" tube overdrive isn't possible without major changes (adding additional preamp stages, etc.), but here's another option:
Preamp clipping can be simulated by installing a diode-clipping circuit. In fact, some big-name amp manufacturers (Marshall and Fender, for instance) have used diode clipping for a more ballsy sound (especially at low volumes.) In fact, it's made a bit of a resurgence in boutique amps...
The danger of converting a tube sound into a harsh "solid state" sound exists. Tubes clip with a softer "shoulder" and have a more pleasant, warm sound....of course, it's a matter of taste, after all.
But a carefully designed diode-clipper circuit can mimic those tube characteristics. "Peak clipping" more closely approximates tubes than "crossover clipping," which is common to transistor design. Plus we can utilize asymmetrical clipping to emphasize the "correct" harmonics. And since our new sound is contained within a tube amp, it will help to soften the effect.
Of course, diode-clipping can be used (and is) for solid state amps, too.
Video clip shows the three switch-selected settings: 1) clean; 2) medium clipping; 3) max clipping:
Warning: This is a "mod," and does require a bit of rewiring. All the usually cautions about discharging power supply filter capacitors apply here. To restate them:
Don't touch the internal components of a guitar amp without first draining the filter capacitors. Please. You could really harm yourself. Here's a link to my older amp project, and the section Discharge those Caps!
Step 1Let's examine diode clipping...
Let\
Wow--at first glance, a diode connecting the the signal path to the ground looks like a short circuit! How can this work?
In theory, diodes conduct current in only one direction. But they don't operate "perfectly." All diodes have a "forward voltage" -- they won't conduct until that voltage is reached.
If a diode is connected between the signal path and the ground, the signal won't be channeled (shunted) to ground until it exceeds the forward voltage. And even then, the whole signal isn't dissipated, only the portion of the signal above that forward voltage. So it's peaks are simply "chopped off."
But it also results in more attenuation, as some of the signal is lost. That isn't all bad! Clipping the loudest parts is also a form of "limiting" -- you loose some dynamics, but accentuate the lower-volume sounds.
Plus, many amps don't begin to distort until turned up too loud for many venues. Like a stomp-box, diode-clipping lends a killer sound at a lower volume. Your family, roommates and neighbors will thank you.
64 comments
1-40 of 64next »
Apr 14, 2009. 8:39 AMCalligraphy says:
So I have a cheap-o First Act bass amp in combination with a Peavey 126 and I want to have my first act act as a dirty channel.(since the volume is lower) Would I have to make any changes in these plans to accommodate bass freq.? This is probably a stupid question but oh well.
Mar 22, 2011. 1:36 PMski4jesus says:
Btw, first act guitars are not all that too baad, i refinished one and it came out pretty nice. and im pretty sure that the bass would not have a difference with that schematic.
Jan 2, 2011. 9:16 PMeyeball226 says:
I just had an idea while reading this... what if you were to have 2 pots (only using 2 lugs), one for each diode. Then you'd have constantly variable asymmetrical clipping. What do you reckon?
Jan 13, 2011. 10:58 AMoweng4000 says:
You have the basis for a circuit by tim escobedo called the "Simple Square Wave Shaper made simpler."
http://folkurban.com/Site/SimpleSquareWaveShaperMadeSimpler-712.html.
Check It out
Jan 15, 2011. 10:22 AMoweng4000 says:
I meant what eyeball226 was talking about. I use diode clipping for all sorts of circuits. I didn't mean that you where copying tim escobedo.
May 28, 2010. 11:51 PMGatedSound says:
I'm confused at the wiring to the lugs of a pot. Which are the diodes attached to, and which goes to the signal?
Apr 26, 2010. 2:38 PMfastcar123 says:
so im thinking of triing this and i always love to make things at easy access so wat i want to know is can this be embeded into the guitar itself?
also would it matter what color the leds are and can i use leds for all of the designs or would it sound beter with real diodes ?
this does work with transistor amps right?
Apr 27, 2010. 4:31 PMfastcar123 says:
so this means i will just need to turn the amps at a higher volume right? or does this work like the volume control and grounds the signal and some of the gain
silicon diodes are the plastic ones that are usually black or grey in color right?
do 3mm leds have lower voltage drop than 5mm
what is a coupling cap
Apr 28, 2010. 1:34 PMfastcar123 says:
but it wil still sound as good right?
so is this stuff sold in radio shack or do i need to buy online
ok none of this matters if it is inside the guitar right?
Apr 29, 2010. 6:52 PMfastcar123 says:
aa boost circuit just makes up for the lost volume right? so is it easy to build and is it cheap ?
i ve thought of bulding one but i dont have any way of powering them (no 9V or AC adapters) also i like to make things as easy as possible
so if yours was custom how do you think i should do mine (just useing signal then wtih the booster)
Apr 30, 2010. 1:19 PMfastcar123 says:
yes i can can get some 9V so is that all a boost is? just a 9V before the diode circuit?
i dont have a voltmeter either so would i just use some diodes htat you have used here?
I didnt know that solid state amps are potentially dangerous because ive disassembled my amps 4 times i think so that concerns me
but doesnt the guitar have a very low (if any) stored electricity when unplugged?
so could i damage my pickups by putting a 9v in its path because they are passive pickups
i was also wondering what would happin if this low volume circuit was turned to a high volume?
the overall question is it this possible to put this in the actual guitar with a booster curcuit with no damage to my equipment?
Apr 30, 2010. 7:27 PMfastcar123 says:
ok 48V isnt enough to kill just to know you back right?
i can try that
and the best way is to have asymetrical on both sides
i can get 1 or 2 batteries yes
\i didnt think it did i just needed to double check from someone more experianced
what about if it is plugged in and the amp is running
May 2, 2010. 8:40 AMfastcar123 says:
thats pretty bad  i need to be more carful with what i do ive been known to fix things and do lots of tests with low voltage things but now it doesnt seem so voltage now
May 2, 2010. 8:00 PMfastcar123 says:
ok so ive bulit mine useing 1n914 type diodes but it doesnt seem to do anything i get the same sound no matter where the switch is and ive built it the same way you did only in guitar itself
Apr 2, 2010. 6:29 PMLeviMan_2001 says:
Any tips on finding the part where pre amp and power amp separate?
Mar 21, 2010. 9:06 AMindrekhaav says:
You mention that you chose, quote, "a combination of two germanium diodes and one LED", yet immediately afterwards you specify a 1N4148 which is a silicon diode. Was it a typo?
Mar 21, 2010. 12:09 PMindrekhaav says:
No problem, and thanks for the clarification.
Jan 27, 2010. 9:36 AMLenny24 says:
I've Used A Zener Diode in my Diode-Clipping Circuit. It doesnt' Work really good, but that could beause I only used a LM741 as "Preamp Stage", and then a 1-Watt-Amplifier-IC out of Old PC-Speakers. I Attached the Diodes after the 1Watt Amp and Put an 10K Resistor after that and Connected it to an Old Guitar amp (That hasnt' OD). I also tried Retifier-Diodes. That Worked a lot better.
Jan 27, 2010. 9:47 PMLenny24 says:
No Promblem! ;)
Jun 2, 2009. 11:18 PMMandela says:
I'm still confused at here (im beginner) If guitar voltage output is beetween .1V and 1V, arent the voltage never been cut because the forward voltage is more than 1V ?
Jun 5, 2009. 6:17 AMMandela says:
thanks oh yes! i almost forget that you made this effect to the amp ! :D But if i want to make guitar effect (not at the amp) i just have too buy lower(under 1V) forward voltage ? thanks again !
Jun 15, 2009. 11:43 AMpyrohaz says:
If you got 0.5v P-P output on your guitar, (Ultra mega hot humbuckers can produce this, or active guitars) You MIGHT be able to get away with this effect using either Signal diodes (Germanium) Or schkotty diodes
Jan 10, 2009. 8:06 PMabadfart says:
nice I've seen this done on one of the tone knobs on the guitar
Dec 10, 2008. 5:36 PMevanconway says:
You probably shouldn't be using A as a possible point in the kay 703, as this is a DC connection from the power amp, and would make a nice path to the ground for the high voltage power supply... until of course the diode dies, or a fuse, or worse, the power transformer. Most cases, what follows would be a smell that forever reminds you. Make sure the clipping diodes are after C2, as this is only AC signal. Fun project! Keep on modding.
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
120
Author:gmoon
