Add Horsepower and Save Gas With a Performance Filter System
Introduction: Add Horsepower and Save Gas With a Performance Filter System
I'm going to tell you how to add horsepower and save gas with a Performance Filter System.
You never need to replace the air filter again!
This works with Fords, Lincolns, Mercurys, BMWs, Chevrolets, and most others.
Now the average added HP is 7-12 HP, but you may gain more or less depending on your car or truck.
If you want to do this on the cheap, I recommend Spectre Performance Parts.
If you want to go all the way and pimp your car out, go with K&N parts.
This is my first Instructable, so go easy. :)
I'm not responsible for any damage you do to your car or to yourself.
Step 1: Measure Your Intake
Most air intakes are 3" but they can range from 1"--6".
Use a ruler, or ask a professional what size your intake is.
Get parts in your intake size.
Step 2: Buy the Parts and Tools
Remember you're only adding 7-12 horsepower, so don't spend all your money.
Here's what you need:
-Multi intake size or direct size cotton media cone filter. (Don't get a steel media filter!!!!)
-Universal-MAF sensor housing, in your intake size, (If needed).
-Square to round-MAF sensor housing-adapter, (only needed with old BMWs).
-Phillips, flathead, and hex screwdrivers. ( You may need more or less tools depending on your vehicle.)
-Microfiber cloth
Step 3: Remove the Old Air Box, Intake, and MAF Sensor Housing
This is harder than it sounds. DON'T RUSH YOURSELF!!!!!
--Start by removing your MAF sensor.
To do this, unplug the cable coming from the MAF.
Unscrew the 2-4 screws on the MAF, lift it out of its housing very carefully!!!!!!!
Then set it on the cloth with the sensor facing up, in a safe place.
--Next remove the MAF housing from the filter box and intake tube.
Do this by unscrewing the 4 screws, attaching the MAF housing to the filter box, then remove it.
Untighten the clamp on the intake tube and slide the tube off the MAF housing.
--Next remove the filter box.
Do this by taking the top off the filter box and lifting out the filter.
There should be some screws on the bottom and/or sides of the filter box,-remove them,
then remove the filter box.
YOU'RE DONE!!!!!!!!!
Step 4: Install the New MAF Sensor Housing
Get the MAF sensor you set aside earlier. GENTLY -put the MAF sensor in the housing. Screw the screws back in.
Re-attach the cable to the MAF.
Next, attach the MAF sensor and housing to the intake tube, and tighten the clamp.
Step 5: Add the New Filter
Simply slide the filter on to the MAF sensor and tighten the clamp. If you bought one of the universal size filters, pull the size rings until you get the right one.
You may need to put an extension tube in between the MAF and the filter, if the filter does not fit where you want it to fit.
In the picture, there's a black tube in between the MAF and the filter, that's because I lost the rubber size ring that makes the filter fit my intake,( you won't need it ).
Step 6: Test This New Monster Out!!!
Double check to make sure that everything is on tight.
Start your car.
If your car is running rough, something went wrong in installation, please go through the steps again or ask me what's wrong.
Please periodically check your filter to make sure its clean, a dirty filter will make you lose horsepower!
To clean your filter, buy a kit and follow the instructions.
Step 7: "Update" -My New Set Up!!!!!
This is my new setup!!!
I've replaced the tubing and the filter with a K&N.;
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    More air, does burn more gas, however this isn't always good.. The power we are getting is the ecm getting a signal from the MAF (if equipped), and running a slightly leaner mixture, now, the air restriction is further down the line. The intake tubing is only so little of the system, the throttle body, then intake manifold, and last the head's valve ports are where it really matters. The small 5hp gains we see is the computer compensating and running lean because the airflow messes with the MAF, on the other hand however... A cold air intake+custom tune(to adjust for higher flow and maintain the proper AFR) will be most beneficial.
    I know this is 5 years old. ScoutTrooper48 (BTW do you SWTOR?) I think you did a great job. Most of the comments here are from people getting mis info from their friends. Hansj3 hit it spot on. The only thing I wanted to mention was having the air filter connected right to the MAF sensor may not be the best set-up. Besides oil from the filter getting on the element inside the MAF (if you happen to add a little too much oil) which will deteriorate the element.. You want to try to reduce "Turbulent Air" coming into the MAF. You can do this by taking the diameter (in this case 3") and multiplying by 3. 3x3= 9. So you should have a straight piece of pipe/tubing after the air filter and before the MAF. In a perfect scenario you should have 9 inches before the MAF and after, but that may be unrealistic. This rule is true in ANY air or water metering device..
    want a build it your self?
    right now, with the setup you have, you are probably getting worse gasmileage, and even worse hp. Hot air intakes DO NOT help your car.... by adding a filter, all you are adding is the sound of the intake sucking in more air. to truly improve gas milage and hp, you need to block the filter from hot air or even run it into the fenderwell.
    True, also you will want to insulate the whole intake system with a foam matress and shield it with ALU...
    This is cool, nicely done instructable. I would do this but I'm already planing to turbo my car.
    I think you forgot one thing. Your car should have an EGR valve, which is a part that recirculates exhaust gasses to the intake, to make the car run "choked"
    I hope for your sake that you covered this valve up, else you are killing your engine fast. Mainly because you are letting unfiltered gasses back into the engine.
    just putting a cold air system on it will only increase the air flow going into the motor, but if you take back pressure off your exhaust, your motor will run much better. Putting headers on and a high-flow catalytic converter would greatly increase your performance.
    The motor will have a better flow with a nice exhaust, but some car need this backpressure, the only thing that might improve your performance is a race designed, COMPLETE, so manifold to muffler system.
    Just swapping one part, for more sound isn't going to help.
    And the cat is usally taken out complete. Best mod to do on a stock system.
    What type of vehicle did you do this on? Would this save gas in a pickup (GMC 4.6L 6cyl, 13-18mpg)? How much more mileage did you get? How long will it take for this pay for itself?
