I put the 3 strips in strategic locations to illuminate and draw attention to certain aspects. I put 2 strips on either side inside the fairings over the engine blocks, where there is a vent hole in the fairing, the lights illuminate the glossy black frame and beefy 4 cylinder engine on either side. The other strip I put under the tail to illuminate the rear tire and shiny exhaust on either side.
After a few tries at a power source and a couple fuses later (I don't have a multimeter, I'm pretty ill equipped) I ended up using the brake/running light to power the circuit (which has interesting results, since when the brake is applied, the power is routed to another circuit to brighten the light, the LED's are extinguished. I think I'll keep it this way because it's more interesting). I also had an unused SAS (Steering Assistance System?) switch on the 'dash' of the bike which was ridiculously convenient, so I wired the lights to that so I can turn them off during day riding.
Remove these ads by
Signing UpStep 1Materials
- Pliers (needlenose)
- Wire Cutters/strippers (I don't have any, I just use the cutter on the pliers)
- Zap straps (zip ties)
- Electrical tape
- LED strips
- Sharpie
- Velcro (industrial strength, self adhesive)
- Appropriate gauge wire
- Multimeter
- Soldering equipment if you feel the need for secure connections (I just twist together and E-tape it)
Anything else you're comfortable using for very simple electronics projects.
what do you think?
http://led.linear1.org/led.wiz
Second option would be to order off Ebay. That's where I got mine and they're super cheap (couple dollars CAD shipped) and reliable (15/15+ sets ordered and received that worked and still do).
Hope this helps!
i live in Ecuador, and well cant really find strips of led´s just separate led´s they are cheap like in the 0.05 to the 0.25 cents range,
anyway i have a 1993 suzuki 650cc and i have some free time and will want to do something like this i like how it looks plus i have free time
so what are you saying is that i make like a glue casting or frame and make my own strip .. never really tought of that, should i include the resistors in the frame?
thanks
