3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Add Sound Effects to your R/C Car
R/C Animator lets you add sounds and lighting to your R/C car, airplane, helicopter, or boat. Effects are triggered with your R/C controller and can be combined.  Here's a demo;
R/C Animator is based on the Propeller Platform USB — effects can include changing the position of a secondary servo, playing back CD quality audio, or changing lights.  On my R/C car, I'm using four LED's and a mono speaker for audio playback.  Continue to the next step and I'll show you how to make it!
Step 1FAQ
FAQ
How does it work?
R/C Animator triggers effects based on the position of the servos in your vehicle.  So, you can trigger the playback of a rumbling V8 when the throttle servo opens up.  Or you could connect a spare servo channel to the R/C Animator to turn on an LED 'light bar' and play a siren.
I'll show you how to customize the logic for whatever effects you want, too.
What effects are available?
Sound playback
Up to 32GB of audio samples can be stored and played back in CD quality stereo.  An onboard audio amp will drive speakers up to 1/4 Watt.
LED animation
Up to 25 LED's can be turned on, blinked, or faded.
Secondary servo movements
Multiple servos can be directly controlled by R/C Animator, so a single wireless channel can trigger secondary servo animations
R/C Animator is designed to chain and combine these effects.
Will it work with my vehicle?
Most likely.  Digital and analog servos use the same signalling method.  If you're using old airtronics servos (non-z connector), you'll need to flip a wire.
How many batteries does it take?
None — It runs off the servo power and only draws a few mA.
What are the dimensions?
7.2cm x 6.3cm x 2.54cm (2.8" x 2.5" x 1.0"). The basic R/C Animator weighs about 40g (1.5oz).  If you use audio, you'll also need to include the weight of the speaker.
8 comments
Jan 1, 2012. 10:19 PMtriggerxxx says:
I'm a noob to micro-controller.
Can you explain how to add more channels to this? And how many are possible?
Dec 17, 2011. 2:42 AMInstructable04 says:
Great instructable! My sister's boyfriend collects lots of rc racing buggies and cars, boxes and boxes of cogs and different parts like that, so this just adds to the inspiration! Just one question...Where do you get the Propellor Platform USB from???
Dec 15, 2011. 1:38 PMK-Note72 says:
How much does the whole system cost to make? (minus the cost of the speaker)
Dec 15, 2011. 2:28 PMK-Note72 says:
Thanks, it's a great how-to that I may be doing in the near future. Yeah I only run electric (nitro=spendy). I came across this because a brand called Tamiya makes something like this but it costs anywhere over $300 so I looked elsewhere & found this one.
Dec 2, 2011. 5:26 PMokoshima says:
nice advert there... hell it seems most if not all your ibles are adverts.. mind handing me that sliced pork and ham flag?
Nov 29, 2011. 10:52 AMFrozenIce says:
Awesome!! if only i had an rc car...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
163
Author:Gadget Gangster(GadgetGangster.com)
