The end result is functional, and safe, but you really shouldn't follow these instructions for any structure you care about, like a home or commercial property. Proper wall strength is important, and the energy efficiency of this installation is not good at all.
Remove these ads by
Signing UpStep 1Idea/Design
Every instructable should explain the motivation behind the decisions made in the project. This project especially, because I'm guessing you can't find the same supplies, or don't have the same shed as I do.
Benefits of a window in the shed:
- Light: a southern or eastern window will probably be a big help in the winter.
- Breeze: A window on the opposite side from the door would create a cross breeze that will cool the shed down in the summer.
- Space: Third benefit, If I am working on something large, there's a chance I will open the window to fit the cut.
Constraints:
- Money: In this case I was thinking $100, but I got away closer to $60.
- Structural Integrity: I won't do anything that I think has a good chance of destroying my shed, or causing major(expensive) damage.
- Time: I want a simple, fun project. I don't want something that will take the rest of the summer to finish.
The conclusion I initially came up with was to find a small, inexpensive window, and try to fit it in between the existing frame of the structure. Once I started shopping for a window, I changed the design to create space for the specific used window I found.
I noticed you had a mitre saw among the tools, so it wouldn't have been any extra work ~ and uses less material. A shorter piece of 4"x1" moulding would suffice...
For my local conditions, I would also consider using flashing on all four sides..
I already have one window in my shed, but I cannot add another as the other three wall are dedicated to storage.
This wall had a bench on it, but I removed it in favor of some mobile tables. I definitely need more storage (who doesn't) but I think the next step is figuring out what I actually need in the shed, and what I need elsewhere.
