loading
today more and more smartphones support wireless charging, whether it's out-of-the-box or via an available hardware upgrade (special back cover). but there is no reason why all other USB charged devices shouldn't enjoy the luxury of wireless charging.
in this instructable i'll show you how to add wireless charging capabilities to your smartphone (demonstrated on a Samsung Galaxy S II) or practically any USB charged device (of course i can't guarantee that it'll work on any device but i see no reason it shouldn't, unless there's some other patent or technology preventing it).
Step 1: background and clarifications
*** FOLLOW THESE INSTRUCTIONS AT YOUR OWN RISK ***
take safety precautions and do not do anything you are not certain of.
i cannot be held responsible to any damage you may cause to your device or to yourself !
(now, after i covered my ass, we can begin)
there are a few projects similar to this one on the net. I've drawn ideas from everywhere and incorporated some of my own.
the whole concept and basic design is based on Palm's technology (although there are other manufacturers offering similar solutions). the Touchstone is a Palm charging dock meant for the Palm Pre smartphone, which supports wireless charging via a separately sold back cover.
there are a few wireless charging technologies made by different manufacturers that all rely on the same physical concept but they are not cross-compatible, you cannot mix coils and docks (I've tried).
i will not bore you with the physics behind the concept (although it's quite interesting) and there's nothing i can write that's not already available with more professional descriptions on the net, so if you want you can google "wireless charging" and read all about it.
Step 2: gather the components
the components and tool needed for the job :
1. a Palm Touchstone - about 15$ on Ebay
2. a charging coil - about 8.50$ on Ebay
. adhesive copper foil
4. a small piece of thin gauge wire
5. a >1000mA USB charger (doesn't have to be original Palm but the cheep chinese ones don't seem to work, i'm working with a 2.1A iPad charger) and USB cable.
6. a case \ back cover \ extended battery cover (w\o extended battery)
7. soldering iron and soldering accessories
8. multimeter (we'll need the volt meter and continuity meter in particular)
9. screwdriver that fits the screws on your device.
10. insulating tape
11. wire stripper and cutter
Step 3: see that everything works and make mods if necessary
before you start dissecting your phone make sure the components you got work.
first plug the touchstone to the charger and place the coil on top of it with the metal sticker on top of the coil.
measure the voltage between the contact points of the coil, you should get between 5.2v and 5.5V.
this doesn't mean that your phone will charge - there's a trick (this was a piece of information that was hard to find) :
the touchstone apparently only works with "fast charge" capable chargers. the indicator for this is a short between the 2 and 3 pins of the USB cable (the + and - data pins) so make sure your charger can supply more than 1000mA and you'll need to sacrifice a USB cable for this - take a USB cable and remove it's outer insulation leaving the wires intact. (no need to cut the cable although its fine too)
cut the green and white wires and expose their tip. twist them together and solder (this needs to be done only on the touchstone side, no need to shorten both sides)
close everything up with tape
note that the cable is much more delicate now, you might rip it if you yank it.
note also that some chargers just wont work (I tried with a 1$ chinese charger that's rated at 1000mA and it just wont charge - while direct connection to the phone works perfectly) try and use quality chargers, for your battery's sake too.
see the photos for a detailed pinout of the USB port, it can also be helpful in the next steps as i will not refer to specific pins but to their use (ground and +5v in particular)
Step 4: know your device
disassemble your device carefully (if you're not sure, there are a lot of disassembly tutorials for almost every device out there) and identify the +5V lead on the USB port and follow it to a comfortably solderable spot (unless you are super skilled and equipped and can solder a single micro USB pin) don't worry about the ground lead, every piece of metal in there is grounded.
in my case (galaxy s II), disassembly wasn't hard, 7 screws and a pry tool \ pick \ fingernail and it's open.
finding a place to solder was a little more challanging, it needs to be a place with enough room for the wire and not too small and delicate for the soldering iron to burn or damage.
i used the capacitor shown in the pictures (i had a little help from google and a multimeter finding it).
after you found your soldering spot, try and find the best path for your lead, it has to connect the + from the coil to the + on the USB.
in my case. i chose to work with copper foil because there's just no room for a wire running along the side and the copper foil is relatively easy to work with.
the main consideration for me when choosing the path was that i wanted the phone to seem (almost) unaltered from the outside and for all the separate parts to stay separate (i didn't want a wire or something permanently connecting the board and the cover).
finding ground :
pretty much every piece of exposed metal should be grounded.
you can check with a continuity meter to see whether a specific piece is grounded or not.
it does not matter what it is you're connecting to, as long as it's connected to ground.
choose the piece that will make your design as simple and as neat as possible.
if no grounded piece of metal can be found you can connect to the USB port ground pin.
Step 5: choose your weapon
the choice of conductive material is crucial. not so for performance but for your device to close properly. smartphones and electronic devices in general get more and more compact with more and more technology inside, which means less "free" space. that is our main challenge.
because of this i recommend using adhesive copper foil, i found that the adhesive is quite strong but non-conductive (duh..) so just placing one piece on top of another is not enough to close the circuit. that means there are two ways to go :
1. doing it all with one long piece. this method is harder because you need to carefully fold and flatten the foil without layering too much foil and without tearing the foil, which i found was pretty delicate.
2. using multiple pieces and soldering them together. while this method might be a little easier and doesn't require super fine motor skills you still need to be careful not to use too much solder and not to heat the area too much and melt your device.
of course you can use thin gauge wire if it fits.
using copper foil creates another problem - it doesn't have any insulation. my solution is just using insulation tape. one layer shouldn't be too thick. you can cut the insulation tape to shape and choose what area you want to cover (something that is much harder when using insulated wire.
Step 6: start taping (or wiring)
you can see from the photos that my system consists of 3 separate parts that together connect the leads. i did that because, as i mentioned earlier, i wanted all separate parts to stay separate.
on the device itself - a wire connects the + on the USB (via the ceramic capacitor you can see in the photo) to a copper foil that serves as the contact for the next part.
on the back housing - a (single) copper foil running from the top of the speaker (that is the contact that connects the former part) to the top right corner of the battery compartment - this is the only part visible outside the device and this will be the contact for the next part.
on the back cover - a couple of copper foils running from the leads of the charging coil to their corresponding contact points (the piece of foil sticking out of the battery compartment and a grounded plate which holds the SIM card in place - that's our ground)
it really doesn't matter how you do it, just make sure the device closes back properly and that you are not shortening any circuits.
Step 7: plan A - fitting the coil under the back cover
plan A implies that there's a plan B. well, there is.
i decided to show you this failed attempt at fitting the charging coil and its circuit under the battery cover because it might be relevant to other devices and even the same one with the extended battery cover.
it appears there is just no space whatsoever between the battery and the cover, not even for the coils circuitry.
placing the charging coil isn't that complicated, just make sure there's room where you place it and that you do not shorten any circuits (the coil and its circuit are fully exposed.
the more complicated part was placing the little metal discs correctly - i came up with an easy solution :
take the cover and coil and place them on the magnetic dock.
the coil might not magnetize well but it should be enough for it not to move too much.
now take the metal discs and place them at the four corners around the coil, they will jump into place thanks to the magnets in the dock.
move the cover around so everything is aligned correctly - the discs should slide on the cover and stay in the same place relatively to the dock. see that the coil is centered between the discs.
take the metal sticker that came with the coil and place it on top of the coil (crucial for it to work)
hold the discs in place with insulating tape.
now you can remove the back cover from the dock and use the copper foil to close the circuit and make the contacts.
Step 8: plan B - discarding the battery cover and using a simple case
well, plan A went up in smoke, unfortunately. (i wanted to use an aluminium bumper as protection for my phone but that means using the original back cover)
plan B is using a plastic case without the battery cover. this is not ideal (especially with the case i chose) but it works.
if i could find the galaxy s II extended battery back cover (without the battery) for sale that would bring us back to plan A (if you know where i can get one - please share)
well the attempt at plan A did most of the work for plan B, because everything is held together with tape i can just peel it off and move it to the case.
the only thing left is to make sure there's contact. the case has more space between it and the phone (when the back cover is removed), that means more space between the contact points.
what i did to address this was to fold some copper foil and solder it to the contact point to fill the gap. this was not enough so i just filled the remaining gap with solder. (see photo)
Step 9: close everything up and troubleshoot
close everything and try to charge.
if it's charging - your done.
if not; try these steps :
1. if there's no sign of charge check your contacts. make sure you have a closed circuit. use a continuity meter.
2. if the charging sign is turning on and off there might be a problem with the charger or the cable, try different chargers or check the cable mod.
3. if your wiring passed under or over any components that also have contact points (like the speaker on my galaxy S II) check that they work, you might have created a gap between the contacts - that's what happened to me with the speaker, opened the phone up and bent the contact springs outwards slightly with a flat screwdriver. works perfectly now.
<p>Nice! I was super excited to see you used a Samsung Galaxy S II- Been wanting to get my hands on one of those to 'upgrade' my iPhone 4s. That being said, I've got a question: Do you still use this phone, and how well does it preform? </p>
Can you please teach us hoy to make byself a palm pre back,?
Very instructive and helpful, thank you for this article. I'm still an amateur in constructions like this one, but will follow every step as described, thank you again!
<p>Hmm, what about several small coils? If I understand the concept correctly, several small circles should, in theory, transfer as much energy as a singular larger coil. My Thought is try and add something like this to a Bluetooth headset. </p>
<p>Very nice write up, it is an enjoyable read and a really neat concept. However, I'm curious if this could be added to other devices... Is charging effected by the shape of the coil? Does the coil have to be in a perfect circle? what about position on the charging pad, does that have to be exact?</p>
Thanks! glad you liked it!<br><br>The coil does not have to be perfectly round, but that might affect its efficiency.<br>In fact, in many other applications that use this technology (i.e. RFID, NFC etc.) the coil is rectangular. i guess you can shape it as you wish as long as it's looped around.<br>You might want to do some experiments and see how this affects the energy transfer.<br><br>regarding the position, it works within a small tolerance of movement. this is why these chargers have magnets to align the phone.<br>I saw some commercial chargers that use 3 coils instead of one to allow for more flexibility in positioning the phone on the charger. maybe a bigger coil would help too, I'm not sure.
<p>is this just a transformer were you pull the coils apart do disconnect? if so why? wouldn't just plugging it in be easier? more cell phone stuff i don't get, still glad i use land lines, no batteries.</p>
<p>Instead of actually touch the cable and insert it into phone, with this mod you can just place phone on the recharge base. It's very nice, but simple dock do the same thing.</p>
<p>i haven't used a cell phone in like 7 years, but the last time i did they only needed 1 cable with a proprietary port for that cell. do they many cables now or somthing?</p>
<p>Lol, no, nothing changes. Except this new technology.</p>
Is this like Wi-Tricity, or do you still have to have to place it on the charging pad, i.e. Cordless?
<p>it's the same technology as any other standard wireless charging on the market today. you do need the pad.</p>
Oh ok cool, try for the clarification.
<p>I run a Mini S3, threw in a Chinese system off Fleabay. In my car, I normally use satnav &amp; bluetooth music to my radio. The wireless charging couldn't keep up with the drain, &amp; the phone ran very hot, so I ditched it in favour of the magnetically held micro USB plugs &amp; sockets. Those work well, up to an amp or more charging. Thanks for putting your 'ibble up, it works quite conveniently for just charging.</p>
<p>wireless charging is still a little slow at ~1A, the chinese ones might even be slower.<br>I also put a chinese coil in my car, but I have a built-in satnav so that kind of offloads the phone so it doesn't draw that much power</p>
<p>Hello, first of all thank you for sharing this cool project. second of all do you think this will work with a flip phone? I have a T-Mobile Samsung flip phone that has the same charging USB connection as most android smart phones.</p>
<p>I don't see a reason for it not to work.<br>good luck!</p>
<p>bb</p>
Universal MicroUSB Qi Wireless Charger Adapter is this is good
<p>Very nice, Great job!</p>
<p>I might just make a case with the coil in it, then have a micro-usb plug in the bottom of the case that connects to the phone. I wouldn't have to open the phone, and if i wanted to charge wired, i could just take the case off.</p>
<p>Hey, Thanks for this great Guide .</p><p>But I Have A Question, Can I use QI Chargers ? </p><p>I mean do all the Steps till Step 6 </p><p>And instead of Getting Palm's Charging Coil i Use QI Receiver and Connect it To Copper Foil ( The 5V from USB port ) http://img02.taobaocdn.com/imgextra/i2/134922319/T2SjAWXfFXXXXXXXXX_!!134922319.jpg</p><p>My Phone Is Samsung Galaxy Grand Duos GT-I9082</p>
You can use whatever coil you want as long as it matches the charger and rated 5v. There's no cross compatibility. If you use a Qi coil you need a Qi charger. You can pick those up pretty cheap on eBay.<br><br>Good Luck!
<p>Would this be possible to do with an iphone 5s? I'm thinking of buying one of those cheap extended battery cases and popping it open, taking the battery out, and right there you already have the connections to the phone within the case and you could wire the coil right to the wires that would normally run from the battery to the phone to charge. </p>
I think that it's possible, I've seen someone do something similar to an iPhone 4s, so I don't see a reason for it not to work.<br>It seems pretty straightforward and you don't even have to disassemble the device. Nice idea.<br><br>I'd appreciate it if you report back after your installation. Good luck
<p>I was very happy to uncover this site. I wanted to thank you for your time just for this fantastic read!!</p><p>I definitely enjoyed every little bit of it and I have you saved as a favorite to</p><p>see new stuff in your site. &lt;a href=http://softwarespin.com/&gt; hashmi. . . . . . .&lt;/a&gt;</p>
<p>Wow, thanks for the warm words. I hope you enjoyed reading it as much as I did writing it.</p><p>I'll have more stuff to upload soon and if you want, you can check out my new blog for some more awesome projects : HarariProjects.com</p>
<p>Very cool mod. Just wondering what happens if you charge the device with the USB port and the QI charger at the same time? Nothing much or something bad?</p>
Most likely something bad.<br>the voltages from the USB charger and the QI charger aren't exactly the same. Generally, hooking up power supplies in parallel isn't safe, if they have a feedback circuit that adjusts the output voltage, they'll fight each other, trying to lower and raise the voltage according to their different reference values simultaneously until something bad happens.<br>The circuits here aren't that smart, but I wouldn't take that chance with an expensive device.
<p>I have a Velocity Micro Cruz tablet someone gave me with a bad usb port. (not positive of the model) I've tried taking it places to have it repaired but they say they can't get parts for it and although I would have expected a USB port to be a standard item, I was told there are literally thousands of different types. I've tried scavenging ports from a few different devices but haven't found one similar enough to work and they seem nearly impossible to remove intact.<br><br>Anyway, stupid question about soldering points... I don't see anything on the board that looks like somewhere that I could solder into near the usb port. The battery has wires that plug into a socket on the board. Is there a reason I couldn't splice directly into the battery wires themselves?<br><br></p>
<p>yes, there is. the battery charges through a special charging circuit that regulates voltage and cuts power when the battery is full. it also helps calibrate the battery. it's not healthy to charge the battery directly</p>
<p>This is true, although it isn't just unhealthy to charge the battery directly, it can be incredibly dangerous in the case of lithium batteries. Without the charging circuit to control the current and switch it from bulk to trickle charge, the battery will overcharge, heat up, and can violently explode. Soldering directly to the battery terminals for an extended time can have the same effect.</p>
If I use one piece of wire, instead of using adhesive copper foil, will that connect to the 5V or the Ground on the charging coil?
As I mentioned in Step 5, the type of conductive material is not important. you can use wire instead of foil. the wire will connect to the 5V lead. the ground lead is the SIM card guard (or any other grounded piece of metal)
Hi, <br>I have tried to modify a USB cable to short the white and green wires. then I connect it to the touchstone. How to check whether the problem comes from touchstone or chargin coil ? <br>
first, the shortened side should go in the touchstone. <br>second, hook the phone directly to the charger without the touchstone to see that the charger is working. <br>third, check whether the charger is rated at at least 1A. <br>fourth, do you have a voltmeter? check the voltage between the contacts of the coil (when placed correctly on the touchstone). what do you read? a little voltage or none at all?
Hi harari, <br>the shortened side is on touchstone side indeed. <br>I did not put directly the micro usb connector to the phone but I have checked with a voltmeter the voltage between pins 1 &amp; 5 and there is 5.2V as expected. <br>The charger is rated 2A. <br>When I put the coil on the touchstone, i read sth like 100mV only... :-( <br>I don't know if problem comes from coil or touchstone actually.
hmm.. when i had this kind of problem it was the USB cable that wasn't modded correctly.. try to re-mod it or try another cable.
I read your instructions and I had a question of since the Galaxy SII and Note i717 have the same charging port and build structuring but the Note has a 2500 mAh battery instead of a 1650 mAh battery I know that it possibly could increase the charge time. But my question is since you modified the charging structure of the device <br>1. how has it effected the battery life of the device <br>2. has the mod degraded battery performance from a users point of view? <br>3. Are you still using this mod or did you revert back to the original charging circuit. <br> <br>I have a Galaxy Note i717 and the charge port has gone bad and stumbled across this posting and in addition to buying a new port for the device, I am thinking of doing this mod to mine as I am tired of my charging issue currently. Thanks!
I haven't really changed anything in the charging circuitry of the device, just sort of &quot;split&quot; the USB port to allow auxiliary power input. <br>1. It hasn't. and there's no reason for it to effect battery life. the voltage and amperage is the same. <br>2. see 1. the mod is completely transparent to the device. it provides the same electrical characteristics as a normal USB charger <br>3. yes, I'm still using the mod and it's working flawlessly. In fact, i bought another touchstone so i now have one by my bed and one on my desk.
אלוף!! <br>גאווה ישראלית!
חח תודה!
Great work, I have an S2 Skyrocket (AT&amp;T)I'd like to try this on. <br>Does the NFC (near field communication) still work after this mod? <br>If I buy a pixi that powers up with a cracked screen (comes with the charger), that powers up, do I still need to buy a coil, or can I use the coil and magnets from the broken pixi?
Hey, very nice assembling! Very clean. <br>I tried to something like that, but not as clean, as I used a micro-usb connector instead of opening my cellphone case because I have a Motorola Razr HD, with does not allow access to the battery. The problem is, it just doesn't recognize the charger. I shorted pins 2 and 3 on the connector, but nothing. I am using an Qi charger, not cheap chinese, and the voltage I measured is fine. Have you got any ideas what may be wrong? Thanks and congrats again!
i haven't tried using QI so i'm not sure. <br>i don't even know if shortening the data pins is necessary. <br>if you measured correct voltage it should charge, have you tried using it on another device? <br>what's your power source?
Hey. I have redone all my connections and now it is working. I really don't know why, but it does. Now I have to get myself a case and that's it. Thanks for the incentive!
Can u tell which android version or template do you use? It's clean and i love it. And nice project very usefull i will try it in future. Thanks :)
i'm using OmegaROM 4.2.2 AOKP and GO Launcher. <br>they are both highly customizable. <br>i like my phone clean and organized, you should see my app drawer, everything is divided into categorized folders. no app icons. -that's the biggest advantage of the GO Launcher over all the others, the app drawer folders (at least for me). <br>i'll post some screenshots if you want.
i hate these things, they just aren't wireless chargers, do people not understand the concept of wires, In fact this is worse than wires because should you want to use the device whilst charging you will have to use it whilst on the charging base unlike a wired device that you simply pick up. <br> <br>Would you call your mobile wireless communication if you had to hold it to a wired in wall to make a phone call, would you call your computer mouse wireless if it only worked on a specific mat and nothing else
there is a battery still attached, so yes, it is still a &quot;mobile&quot; device. also, if you notice, he didnt remove the charging port. he simply created a double input of power. he can charge it with a cable, or on the dock. but, for the sake of all the others imagine this: <br> <br>You walk into your house, after a hard day at work. all you want is rest, but your phone is about to die from all the phone calls you were doing all day. great, now you're gonna have to spend 10 minutes looking for the charger cord. and when you find one, it's not the right size. there goes 10 more minutes. oh, that's right. you remember that you had a dandy wireless charger installed in your house. the wires encompass your whole house, so there is nothing to worry about. you look at your phone, go to settings, press a button, and voila! your phone is charging, no cords, no hassle. you may now rant about how much you need wires. <br> <br>PS: this idea is a system that I'm working on with a couple friends, maybe ill make an instructable about it. <br>PSS: thank you for the 'Ible! this helps so much! :D
About This Instructable
497,184views
1,662favorites
License:
More by harari:3D Printer Lead Screw Upgrade Magnetic Push Pins Add Wireless Charging to Your Smartphone
Add instructable to:
