Disposable diapers are very hard on the environment. That's why my wife and I use cloth diapers. Instead of sending pounds and pounds of soiled diapers to the dump every week, we simply wash the diapers in the washing machine. However, you can't just dump the dirty diaper directly into the machine! That would be... truly nasty. You have to clean off the majority of the solid waste before it goes into the laundry. Sure, you could use paper towels or wipes or something to get the chunks off, but that's a waste of resources and it takes too long and it's smelly and gross.
So why not spray it off -- directly into the toilet? Commercial units that do the same thing cost $40-$60, but you can make one for $30 or less if you have the parts lying around.
EDIT: Instructables member Catflavor has alterted me to the fact that some sort of backflow prevention would be a Really Good Idea for this installation. In fact, it may be a legal requirement where you live. In Canada, either a vacuum breaker or an RPZ (Reverse Pressure Zone) valve may be used, and the sprayer will then be completely up to code. Unfortunately, these are somewhat expensive and complicated to install. I'm looking into my options and will report back. In the meantime, if you use this sprayer, I suggest shutting off the water at the valve before releasing the sprayer trigger *just in case.*
AND A PLEA: Please vote for me in the Epilog Contest! Why? Because if I win, I will be donating the laser cutter to the fledgling Maker group starting up in my city. It would go a long way towards our goal of a Maker/Hacker space in Waterloo!
Remove these ads by
Signing UpStep 1Parts and Tools
For those who have never had to change a baby poop, it ranges in texture from a thin paste to a solid lump. Green guacamole poops are the worst. They're all nasty to clean up. What we're going to do is splice a hand-held kitchen sprayer into the water line that feeds the toilet.
The sprayer can be used to wash the larger chunks of poop into the toilet, where they can be flushed away. The diaper can then be put into the wash.
Here are the parts and tools you'll need:
1 T-junction with one male 3/8" compression joint and two female 3/8" compression joints
1 valve with 3/8" compression joints (optional)
1 3/8" compression to 1/4" threaded pipe joint adapter
1 kitchen sprayer wand with a 1/4" connector
1 2" long piece of 3/8" OD plastic tubing
1 stick-on hook (optional)
*** 1 vacuum breaker or RPZ valve
plumber's tape
an adjustable wrench
rags
*** this item was suggested by another Instructables member as a recommended heath & safety device. I am currently attempting to source something that is compatible with this setup.
Thanks
Also to avoid the stains in nappy we fill a bucket of water with detergent add a drop of viniger and let the nappy soak over night (after removing the poop of course). In the morning everything goes to the washing machine....the nappy stays nice and clean.
Before I explain the dangers, I do want to say that I am not attacking this design on principle. I love the idea and I come to Instructables especially to see the energy and waste saving ideas that people share here. The concept is great, it just needs to be done safely. Its especially commendable for the potential for reduction in disposable nappy landfill. But please please don't implement it in the format shown here.
The danger comes from a lack of BACKFLOW PREVENTION. This means that in some circumstances it would be possible for human waste including fecal matter (poo) to get drawn back into the spray head (simply because the spray head could become immersed in the toilet pan or someone might use the head to 'massage' water into a stubborn bit of ...dirt). Water with fecal matter in is a "cat 5" risk in the UK. Cat 1 is safe drinkable water. Cat 5 is the highest danger category. It is considered as dangerous as butchery waste and biological pathogens. Its is considered more dangerous than chemical waste, pesticides, bleach and detergents.
Please see:
http://www.wras.co.uk/PDF_Files/WRAS%20Regs%20leaflet.pdf
for some details of this sort of installation. This would be the equivalent of a "bidet with ascending spray or ascending hose". Parts 2 and 3 give the warning about this. I don't have the actual regulations to hand to cite the advice and requirements from there. In any case these may differ in exact detail in any country. Suffice to say, its a presented as a risk so that you, your family and your neighbours don't share illnesses and risk of disease.
These bidets can be installed in the UK with the correct backflow prevention. But they are considered such a potential risk to health that they you are required to inform the local council that you intend to install one and prove that it will be done safely.
Sorry to put a downer on an instruactable like this. But it is better that everyone stays safe and that people don't go installing something in their home which they could be prosecuted for or which could harm the health of their family and neighbours.
Others have commented that this sort of installation is common where they live. I am sure that in these cases backflow prevention measures are built into the water supply to the device by the manufacturer or installer when planning is sought for the building. One plumbing installation can look similar and seem to work just as well as the next one, but a qualified plumber in your country will know how to isolate this sort of spray head from the mains water supply safely and will also know when regulatory planning permission is required for any type of installation.
It is also a criminal offence in Australia to install any item with potential backflow problems, especially those that may affect potable (drinkable) water supplies.
For those that don't know Australia is one of the countries in which you can drink the water that comes out of the shower, and the tap/faucet. This may sound silly to bring up, but there are many countries that you cannot do this.
I don't mean to be a party pooper either, but there is a potential for danger, not only to the persons who make this instructable, but their neighbours. And like Catflavor I must stress that public safety is a must, and risk of prosecution is something that needs to be taken into consideration.
So to steal my final quote from Catflavor One plumbing installation can look similar and seem to work just as well as the next one, but a qualified plumber in your country will know how to isolate this sort of spray head from the mains water supply safely and will also know when regulatory planning permission is required for any type of installation
