3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Add a Shower to your Toilet
Step 3Assembly - Part 2
Assembly - Part 2
It's time to move things to the bathroom.
Locate the short piece of flexible hose that carries water from the valve to the toilet. Turn off the valve (turn it fully clockwise), then flush the toilet. This will drain the water in the tank.
With a rag under the valve, unscrew the hose from the valve and allow any remaining water in the hose to drain out.
Grab the splice you created in the previous step, and screw it onto the output of the valve. Make sure it's good and tight. Since this is a compression fitting, you won't need to use plumber's tape. Now screw the hose from the toilet onto the top of the T junction.
That's it! You'll probably want to add a hook somewhere for the sprayer. It help make everything a bit neater, and you won't trip over the hose when you stumble half asleep into the bathroom in the morning.
7 comments
Nov 8, 2010. 10:37 AMVladan says:
What is the point of adding a COLD shower to the toilet? Most toilets are close enough to the shower/bathtub, so why not just replace the shower head with the hose (for some reason this is a default setup almost anywhere except North America)?
Feb 24, 2012. 11:24 AMRich99 says:
well, i use it for my bum, too, when my roids flare up... feels kinda good and gives me the cleanest a**hole in the state. (no more skid marks.)
Nov 8, 2010. 3:48 PMVladan says:
Ahaaa (slap face)! It's a good idea then.
Apr 9, 2009. 10:33 AMmabeena says:
I just forwarded this to my friend who is due in a few weeks. This is genius!
Apr 4, 2009. 8:14 PMrugergirl79 says:
amazing!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
345
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
