3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Add a cooler to an ATI All In Wonder 9600 VGA card
The ATI All-In-Wonder card is a great value for the features, so I'm sure many people bought one when they were available. One reason that they were a great value was slower, cheaper components, so the card will do a lot, just slower than average. One area of cost saving was the heat sink for the VGA chip. All cards these days have a heat sink with a fan, but not this guy!
My PC overheated a while back. It was better after I cleaned the dust bunnies out of the heat sinks (remember to do this, kids - maybe when you change the batteries on your smoke detectors, about twice a year). However, I noticed that the VGA card got VERY hot - this was unacceptable, so I decided to upgrade the cooler.
Unfortunately, I couldn't find any coolers available for this card specifically. There are many generic "compatible with all ATI 9xxx" coolers out there, but don't be fooled - these rarely work with the All In Wonder. I managed to alter one to work, and here's how I did it.
Step 1Overview
Overview
  • C:\My Documents\My Pictures\instructables\vga_cooler\Img_01.jpg
  • C:\My Documents\My Pictures\instructables\vga_cooler\Img_01b.jpg
The ATI All-In-Wonder 9600 (hereafter refered to as the AIW) uses the Radeon 9600 chipset, but it has a bulky TV tuner module and tall capacitors that prohibit using a typical ATI 9xxx VGA Cooler. You need either a very tall narrow cooler, like a 486 CPU cooler, or a cooler that uses heat pipes to get the heat sink clear of the board.
I decided to use the Accelero S2 VGA Cooler, made by Arctic Cool. It uses heat pipes. It is designed to run in a silent PC, so it has no fans, and the heat sink is HUGE (but surprisingly light). Arctic Cool does make an optional fan kit for this cooler, but I decided to increase the number of fans on my case instead.
The Accelero S2 isn't a perfect solution, as it needs to be modified to fit the AIW card, but the modifications are minimal. It just involves making a few cuts in soft aluminum with a Dremel tool or hacksaw.
The cooler kit has heat sink compound pre-applied, and comes with a blank case-card cover with vent holes in it, so that when you mount it next to the VGA card, there is an extra vent hole in the back of your case. The kit also comes with 8 heat sinks that stick on to the RAM chips, and even though I haven't noted any high temperatures at the RAM (I don't overclock), I installed them anyway.
8 comments
Nov 21, 2007. 8:21 PMPunkguyta says:
What in your right mind makes you think you need a 10 pound heatsink for an All in wonder?
Nov 27, 2007. 2:10 PMPunkguyta says:
Actually your answer is possibly wrong, I will try to elaborate despite your 1-upism below: Given time for the computer to be on, the heat sink will eventually heat up as hot at that other smaller heatsink that was factory installed. So, we had a fan right? Well with such a large new heatsink, we'll need a bigger fan to keep it cooler because of the increased surface area on the heatsink takes more air moving around to cool it. Thusly using more electricity and not really saving the environment.
Jun 22, 2011. 9:53 PM_Scratch_ says:
Actually, you are wrong. The point of a passive cooler is to have a large surface area to disperse heat across. Hot air also wants to move up, so there is a constant movement of air, even without a fan. It does not require more air moving to cool it, quite the opposite actually, the reason why the passive sinks are so big. The more surface area, the more heat transfer to the air, which better dissipates heat, heating the air up more, which causes more hot air to rise, and more cold air to move up into the sink. Do not rely on electricity for everything, nature has its own tricks.
Jul 7, 2009. 4:26 AMpunkatsub says:
(removed by author or community request)
Jun 22, 2011. 9:48 PM_Scratch_ says:
The only High end PCs ive seen running 2 or more gpus are Alienware, or home built computers. My computer isnt incredible., but i built it. Also, to punkatsub, if you play any graphics intensive games (pretty much any after 2007) need a independent graphics card to run on high detail and smoothly. Such as Modern Warfare 2 on the computer.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:exabopper
dot-com crash casualty
