loading
Step 5: Close it up
Now put the trigger bar in the other half of the gun, you need to because of the spring. put it in at an angle and lower the rest of the trigger bar in place. you may have to hold the trigger bar when you put the other half on.
you need to push the spring against the plastic stopper that it originally pressed against.
Dont forget to snap the orange clasp back in.
wow any ideas about adding recoil <br><br>im looking into this for a project of mine does it feel hevay or light cheap plastic
you could probably try using a vibrating motor, thats probably the closest you can get to recoil.
A small solenoid could be used, one on each side to give you a balanced movement and not screw up those perfect skeet shots on Wii Play. ;)
About This Instructable
1,812views
4favorites
License:
Bio: I like to modify things, make things, and modify the things i make. im no math whiz or someone with perfect grammar, but i am ... More »
More by zack247:PCB etching.. with vinyl! Repurposing a cell phone - the making of a rechargeable battery pack. Glowing paw sound reactive laptop
Add instructable to:
