Add a rapid-fire button to your mouse using a 555 timer
Does your finger get tired easily while playing video games? Ever wish you could pwn n00bs faster than the speed of light without ever breaking a sweat? This Instructable will show you how.
Step 1What you need
What you need
Originally, I built this circuit specifically to make the Engineer/Scout's pistol in Team Fortress 2 more effective, but I've found uses outside of TF2 that increase productivity when I'm working, which makes this an incredibly useful mod.
This circuit can be added to any mouse. Yes, that's any mouse, following these simple steps.
For this Instructable, you will need:
- 555 Timer IC
- 8-Pin IC Socket (static discharge or heat from soldering tends to ruin 555s, so we use a socket)
- 10K Resistor
- 1K Resistor
- 4.7uF Capacitor (voltage doesn't matter, as long as it's 5V or over)
- Normally-Open Pushbutton Switch (any kind will do)
- Some wire
- Glue (to adhere the switch to the mouse, so hot glue or epoxy will work well for this)
- Solder
- Soldering Iron
- Wire snips
- Fine-nosed Pliers
199 comments
1-40 of 199next »
Feb 3, 2012. 3:50 PMMintyCondition says:
Awesome! Worked for me perfectly!
Jan 30, 2012. 11:55 AMNinjanator says:
i made this but when i use it it only clicks once
Dec 5, 2011. 1:55 PMzigzagchris says:
Is it not possible to use a hack on the computer?
Sep 29, 2011. 12:35 AMpikagod says:
I don't normally post comments, but I am actually trying this project and I planned on doing exactly as someone else here did. I want to add an on/off switch instead of a button, but wouldn't the button simply be completely disabled when the switch is in the off position? meaning the clicking wouldn't work period when its off?
Sep 5, 2011. 9:44 PMmrodríguez hernández says:
It works only while the button is pressed? or have i to apply a "reset"?
Greetings
Apr 17, 2011. 8:57 AMsmartbuilderperson says:
fun project i have done this it works great. i tried it on roblox....but did had to change some settings
Feb 13, 2009. 9:25 AMausetisis says:
could you vary the speed with a potentiometer and were could you put it?
Mar 24, 2011. 8:38 PMbdeschamps says:
take out the 1 k if i remember right and put it there, I mite be wrong I have done it before I just can`t remember.
Feb 14, 2009. 12:47 AMhevitikku says:
yes you could. put it instead of 10K resistor
Feb 18, 2011. 4:24 AMMax_Veteran says:
IS this possible to use this for games such a cs 1.6 ?
Oct 16, 2008. 5:26 PMAustralLord says:
is there a way to make it shoot faster?
Jul 7, 2010. 7:49 AMjimday666 says:
sure, but specific games have limitations too. have to experiment.
Jan 21, 2011. 2:53 PMoliverkrystal says:
Good place for a potentiometer, don't you think?
Jun 26, 2010. 6:54 AMtrunkmonkey4345 says:
I just finished this mod and my mouse lost power on the optical light and cant move it anymore but the mouse can click fast any ideas or does anyone know whats going on
check for a traces that has got extra solder connecting them. You probably soldered one thing to another
Jan 5, 2011. 10:39 AMMarche says:
Just a heads up; you probably shouldn't leave the reset and control pins floating. With the 555 I used I just tied the reset pin to VCC.
The control pin should be connected to ground with a 10nF capacitor.
After that it should work fine.
Apr 22, 2010. 6:53 PMEvilthingamabober says:
Nice job, but a script may be more convenient. Here's one that I amde in AutoIt.
Press " ` " to use it.
www.box.net/shared/ffmdzo5hxj
Dec 29, 2010. 1:53 PMddevun says:
The problem with a software solution is that it can be detected by anti-cheat software (Punkbuster, Warden, etc.). The only way this could be detected is visually by other players or administrators.
May 5, 2010. 9:22 PMThe End of A Heartache says:
the 555timer is a fancy flip flop .. it doesnt have a ic chip its all resistor,capacitors inside ... i used an EN555 on a rapidfire mod on a 360 controller.. creating one on a mouse is very intresting.. will it work on a wireless mouse though? i own acouple of cheap $15 wireless mouse i would like to try this out on
Dec 5, 2010. 12:17 PMThat Smith Kid says:
*facepalm*
IC stands for integrated circuit. The 555 is a circuit made up of resistors, capacitors, and (I believe) a transistor, all integrated into a single chip for ease of use. Pretty sure that makes it an IC.
May 8, 2010. 2:36 PMmatstermind says:
it will
May 8, 2010. 4:45 PMThe End of A Heartache says:
Im wondering it will drain the battery.. i used alkine and being that my cheap mouse they drain the battery like alchoalics to a bottle of wine
i think its time i should buy rechargable type nickle metalhydraite .. or cadimum
what type of 555chip did you use in the experiment?
May 8, 2010. 7:31 PMmatstermind says:
and i'd DEFINITELY go with rechargeable batteries
May 8, 2010. 7:28 PMmatstermind says:
it won't drain the battery if you put the switch between the powersource and the timer. and i used a TLC555CP from texas instruments, i got it as a free sample.
Sep 28, 2010. 6:15 AMhtetkyawlwin says:
really a cool idea for gamers :)
also I think 17xxxx type is lower drain current than other 555 ICs. such as 17555, 17741 etc.... but I'm not sure.
Mar 19, 2009. 4:12 PMuger iceman says:
what resistor should I use if i needed it to run off 2 AA batteries
Dec 2, 2010. 9:02 AMMarche says:
IIRC, the resistors are there for timing purposes, if you're still wondering.
Make sure your timer IC can run off of 3V though!
Oct 25, 2010. 8:42 AMDannne11 says:
what happens if i skip the Capacitor??
Jun 19, 2010. 8:18 PMArirox says:
can i add a small on/off switch like:[See Pic]  insted of the push switch used in this mod?
Sep 28, 2010. 7:59 AMmatstermind says:
yes
Aug 9, 2010. 4:22 AMknex_mepalm says:
Is it possible to make it a dual shot instead? Because I am a fan of the ak47 in shoter games and it always kills in 2 shots but I waste like 5 shots afterwards. Help? I just need a diagram.
Sep 28, 2010. 6:07 AMhtetkyawlwin says:
You could use 555 and CD4017 decade counter IC to make only 2 shot.... today many kinds of mouse come with a button to avoid double clicking the left button, that would make you easy in your game because it's make only 2 exact clicks :)
Aug 10, 2010. 3:20 AMdarthpotato1 says:
so what wattage of resistors did you use 1/8, 1/4, or 1/2? does it not matter?
Jun 22, 2010. 6:08 AMArirox says:
I Made A Schematic Of The Circut that is easy to follow :)
Jun 18, 2010. 2:15 PMN3v3rm0r3 says:
Can this be used as a switch that turns on and off quickly??
May 28, 2010. 4:47 AMStaffboat says:
Just to point out if you wish to say that Pin6 is connected to Pin2 you must use the small dot which indicates that the intersecting wires connect or attach
Aug 14, 2009. 8:47 PMitsachen says:
The new patch made the pistol fire at a fixed rate, not how fast you click. D:
Nov 3, 2009. 1:07 PMColonel88 says:
But wait, it still works on Counter-Strike Source's double pistols! Yay!
1-40 of 199next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:mothflavour2
