Add an extra pane to your windows
 by Mar HK
I have an old house, and two of the windows are still single paned. As part of my ongoing energy efficiency improvements, I wanted to reduce the air and heat leakage from them, and reduce condensation on the glass. Since it's not in the budget to replace them this year, I needed a reasonably priced fix.
I decided to add a pane of acrylic on the inside of each window.
Materials:
- Clear acrylic panes (plexiglass, lucite, etc)
- Double sided foam tape (found in the weatherstripping aisle)
- Cove trim (optional) and fasteners
- Caulking
- Dessicant (optional)
Tools:
- Work gloves (acrylic can be very sharp)
- Safety glasses (you like your eyes, right?)
- Measuring tape and pencil/pen
- Exacto knife
- Miter box and saw
- Caulking gun
- Hammer (if nailing on trim)
Step 1: Air seal the window
The first thing to deal with is air leakage. I got out the trusty caulking gun and caulked around the edge of each pane of glass, and filled in any gaps around the window frame. The caulk I used is water based clean up, so a wet finger made sure that I got all the gaps, and a damp rag cleaned everything off the glass. I used white indoor/outdoor 25 year caulk.
Let the caulk cure, per the tube instructions. You want the window and caulk very dry before you install the acrylic.
dreiseratops says: Nov 21, 2011. 6:13 PM
Id love to hear about temps & energy cost reductions through the coming weeks.
Looks good.
psullivan1 says: Nov 21, 2011. 9:21 AM
If they end up fogging up, you could drill a small hole in the plexi. Cool instructable.
Mar HK (author) in reply to psullivan1Nov 21, 2011. 11:54 AM
I'm hoping that once things warm up again the dessicant between the glass and plexi will dry out the air trapped in there.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
