I will show you how to
1- add a usb power supply that will be coming out from the dash to power my phone that I use as a GPS when it is attached to the windshield
- running the wires
- powering them (see number 2)
- making a 12v to USB power circuit (both the complete DIY and the hack-up-an-existing-device ways)
- connecting the device to the power supply
- making a face plate
- small snips (to cut tin plastic and wires)
- needle-nose pliers
- a flash light
- Hot glue gun
- Screw drivers (or whtever tool is needed to dismantle the adaptors)
- 1 inch or 3 of an inch fuse container (depends on the device you are using)
- soldering iron
- solder (and flux if you have some, but if you don't no need to buy it, fresh solder added is enough to re-flux old boards)
- Ethernet cable (easiest way to thread many wires at once and they are stiff enough to be easier to thread in the car)
- USB port (can be recovered from any device or bought new or you can skip this and solder directly to your usb cable, not recommended due to the type of wires used in usb cables)
- snap connectors x 10
- wire (2 different colours can save you lots of headaches)
- a usb to 12v adaptor
- a L7805CV voltage regulator, part number 497-1443-5-ND from Digijey
- a 220uf 16v Capacitor, part number P5139-ND from Digikey.
- female USB ports times the number of ports you want (2-3 would be normal), Digikey number AE9923-ND
- if you choose to add an LED, you need an LED and an appropriate resistor for 5V. This depends on your LED's rating. Any LED will do, here are the values for the most common LEDs : 1.2v = 220ohm, 1.6v = 180ohm, 2v = 180 ohm, 2.2v = 150ohm. If you have a strange LED or want to make it brighter, please use this resistor calculator.
Remove these ads by
Signing UpStep 1
I removed the paneling in the order show in the picture with numbers on the panels. It takes a bit of patience, a good flashlight (if you have one that goes on your head, it will save you lots of trouble) The red line shows approximately where I wired it. long needle-nose pliers can bu useful too for reaching. Make sure the car is OFF.
10
comments
Add Comment
Add Comment
