Adding Bluetooth to a Motorcycle Helmet
73,317
102
15
Published
Introduction: Adding Bluetooth to a Motorcycle Helmet
Riding my motorcycle for long periods of time without any sort or radio got dull quick. I started to wear my bluetooth earpiece inside my helmet, but it was anything but comfortable. So I decided to add bluetooth to my helmet, but helmet kits were expensive going over $100+. Looking around on amazon I found a cheap stereo bluetooth headset for just $25 which I integrated into my helmet. Here's how I did it.
Step 1: The Headset
The Bluetooth headset I used was the SoundBot SB2200. It cost me $25.
Step 2: Unscrew the Screws
After unpacking the headset, you're going to want to pull off the ear cushions. Then get your hands on a small flat screwdriver and work those screws off. They're non standard screws, but with a little maneuvering you can get them off no problem.
Step 3: Pull the Wire Out
Now with the earpieces apart, make note of where the wires go. You're going to unsolder them in order to remove the wire from the plastic neck strap.
Step 4: Make a Hole
Find a good spot to mount the controls on your helmet. Make a hole large enough to pass the wires through. I don't show it here, but I removed all the cushions from the inside of my helmet to make maneuvering  of the wires easier.
Step 5: Mount It All
You're going to need some spare wire to extend the connection from the speaker to the main board. Also you're going to need to remove the microphone from the main board and mount it somewhere in your helmet. When you've done that, just run the wires to the hole in the side of the helmet and solder them back onto the main board. Use the previous picture for reference if you have to.
Step 6: Finished Product
Now for the finishing touches. I reattached the plastic pieces to the speakers and hot glued them in place inside my helmet. Then I removed the tape from the controls, placed them in an appropriate position and glued it down and made sure to glue all the way around rim so there were no gaps. Test it out. Mine worked great. It was loud, I sounded clear when i talked through the microphone. All for $25. Saved myself  $100!
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    15 Discussions
    Yeah, it's funny how people don't realize that this destroys the structural integrity of the helmet, making it much more unsafe.
    fnunes
    2 years ago
    Lvultao first of all, great project. Wanna try something like that (minus the drilling lol) anyway so you have any picture of the board from the side of the buttons. Really wanted to make the board waterproof with silicon or something like that.
    this is good. I thought u would be drilling a bog hole but I feel this hack is beautiful.
    Thanks, although in hindsight I should have but the controls on the left side instead of the right :-/
    Oh yes. Haha. I generally keep the visor open so I can cool my head ( let the air in)..BT no use investing in noise cancellation headphones. Would make it too expensive, for me, just for the helmet. Thought abt making it waterproof?
    Besides sealing up around the control panel with hot glue, I don't plan on doing any more to it. I only rode in the rain once, didn't have any problems.
    So, a year latter, how is it holding up? I take it, from the ad on Amazon that these are somewhat water resistant. How about the battery? How is it holding up? It sure looks big in that picture. I don't see how they fit it inside the headset!
    It held up pretty well for as long as it lasted. I ended up getting a new helmet because I crashed with that one on. The force of the impact popped off the controls, so I'd suggest finding a better way to secure it to the helmet. As for battery life, it was great for the few months I was using it. The battery was mounted in the speaker housing without the control buttons, but I rigged it in the helmet closer to the controls because i had space there. The only thing I could probably complain about was that I wish it was louder, but for a $20 hack; it was plenty.
    Does this headset come with two speakers? if so then did you mount the other one on the opposite side in the same fashion, minus the hole? I'm getting the same headset as you, so i'd like to do this the same as how you did it. Thanks!
    Alright that's what I figured. Thanks a lot.
    okay looks nice but if you drill the helmet you loose the strength and in case of crush... your surgery will coast more than a Bluetooth motor pack... i hope you dont crush before you read this
    This is a mod you should certainly think well about before attempting. If you're uncomfortable with drilling you can always position the controls in a location that will allow you to pass the wiring through without any drilling. It might not be asthtically pleasing but it will certainly make you more comfortable. I'm not sure whether or not the tiny hole you create makes much a difference, because I'm no engineer, but I was in an accident where my bike slid out from under me and i slamed my head against the pavement. The controls flew off because of the weak hold of the glue, but the helmet still did its job protecting me dispute the small hole I had created for this mod. But as with any modification you make to safety devices, as soon as you start messing with it the manufacturer can't guarantee it'll be the same. Anyways, good luck and be safe.
