Introduction: Adding Entries
Picture of Adding Entries
Adding Entries on the Registry Subkeys of the Company’s Knowledge Base System
In order to add a registry value into the knowledge based system, make suitable changes in the registry. After making the changes, export the subkey. Any exported subkey will be saved automatically as a .reg file. To add and export subkeys, follow these simple steps:
Step 1:
Picture of
1.
Click start, then click run, type the word ‘regedit’ in the open box and finish with clicking ok.
Step 2:
Picture of
Locate and click the subkey with the required items for changing.
Step 3:
Picture of
Click file followed by Export.
Step 4:
Picture of
In the given File Box, type a file name for saving the registry items. Use a file name that reminds you of the items within the file to ease reference procedures and calls.
Step 5:
Picture of
In the file box, locate the right pane, which will be used to save registry items.
Step 6:
Picture of
In the right pane, add the registry items to the saving file as desired.
Step 7:
Picture of
Repeat the third and fourth steps to export the subkey another time, but apply a different directory name for the .reg file. This .reg file will be used to make any other registry changes required on other computers.
Step 8:
Picture of
Test the changes on the local computer. If there is a problem, double click the backup file with the original data registries in order to convert them to their initial state.
Step 9:
Picture of
Locate five other computers in the network and repeat the testing process to change any failing files to their original .reg state.
Step 10:
Picture of
If the tests are successful with no problems, distribute the .reg file to other computers in the network by using the method that will be input in the ‘Distribution of Registry Changes’ folder in the administrator network workstation.
DIY Hacks and How Tos (author)2015-11-01
Thanks for sharing.
About This Instructable
91views
1favorite
More by kqksq:Adding Entries
Add instructable to:
