3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adding Led eyes to the mack bulldog hood ornament
  • last photo ←
The bulldog hood ornament is on just about every mack truck across the globe. I managed to get one, mount it on a jeep, and led lights for eyes. This instructable explains the led mounting procedure in non technical terms so your rig (or bike, kayak, dune buggy, etc) can have glowing eyes.
Step 1Procurement and Parts
Bulldog Procurement
the mack truck bulldog hood ornament is available for purchase on ebay or online
I purchased it 6 years ago at a tour of the mack truck factory for 30 dollars at the time. it might also be a good idea to find a big scrapyard and check.
leds
i used 3mm (aka T1) bright led's check mouseror digikeyfor the brightest ones available for the color you choose. 5mm led's would be too big and look dorky. its also good to use clear led's so that when the eye's are off they look like part of the silver structure, not little red dots. resistors can be purchased at radioshack or along with the order.
Current Limiting Resistor
the resistor value you use is dependant on the led used and the power supply for your vehicle. for an led with a vd or forward voltage of 2.6 volts and an id or forward current of 20 milliamps (see datasheet image) and a vehicle with a 12v supply here's the procedure for determining the correct resistor value
(vehicle voltage - vd) = vdrop so:
12v-2.6v= 9.4V= vdrop
using R=(V/I) substitute values in place
R= 9.4V/ 20 ma = 9.4/ .02
so R = 470 ohms
the power dissipated across the resistor is calculated from P=IV
.02*9.4=.188 Watts , so a 1/4 watt resistor (common at radioshack or real electronic parts store) is ok to use. chances are a 1/2 watt resistor might be better suited as the resistor wont be able to dissipate much heat into epoxy.
15 comments
Feb 2, 2008. 5:22 PMuncle_al_0 says:
Correct me if I'm wrong but isn't it illegal in ALL states to have any red lights facing the front? Not that thats going to stop me from doing it ; ). One of the dogs came on a pickup i just bought.
Aug 10, 2010. 12:01 AMzack247 says:
well they say that its illegal because that it would signify a taillight, but i think that people will see 2 bright white headlights before they see 2 little red lights. especially through their car mirror. he should be ok, and unless you look closely in the mirror, its more of a close up decoration than a far away one.
Apr 29, 2009. 3:55 AMwupme says:
If you drive fast enough, the red will appear green because of the doppler effect, You just need a bit less then 15% lightspeed for that or 45.000 kilometers per second. You see, that red aint a problem if your car gots enough horses.
Dec 28, 2008. 2:24 PMbigedvan says:
do you sell the mac dog with red led eyes if so let me know i would like to purchase. bigedvan@hughes.net
Feb 4, 2008. 5:16 PMuncle_al_0 says:
Orange is perfectly fine to have on the front, look at your front blinkers for example, but i think you should be fine I'd just leave them until you get pulled over for it. At worst you would get an actual written warning.
Apr 29, 2009. 2:28 AMhack124x768 says:
Been meaning to put a mack dog on my renix cherokee for quite a while now. Nice jeep. :p
Mar 9, 2008. 12:19 PMstasterisk says:
Sweet! Arf!
Jan 7, 2008. 7:37 PMrudolph says:
An anecdote. My grandfather used to say (living in Idaho) "It's cold enough to freeze the balls off a brass bulldog!". A few years back my dad acquired a Mack bulldog, so we sent it to the shop for a copper dip (brass dip isn't what you think it is) for Fathers' Day. They tried to sandblast the chrome off and found the sand blew through the pot metal the dog was made of... They acquired a replacement, bead blasted instead, dipped it in copper, and threw in a nice custom wood base (for our time and trouble). It sat on Dad's desk a year or so, then the house burned down... I like this, the led eyes are pretty cool. Forgive me for not wanting a Mack bulldog near my house ever again :)
Jan 5, 2008. 8:20 AMllamafur says:
that would be stolen so fast, but wait. why not put a 50,000 volt charge through it. aka ( a flyback transformer) I'm stupid enough to know
Jan 5, 2008. 6:39 AMleebryuk says:
That's pretty cool. Definitely one I'll keep in mind for my next beater. If you want to get the noise down inside your jeep, try insulating the hood. There are specific materials (sort of like a blanket with a sticky back) that will really cut down on the noise at highway speeds. Check with your local auto supply house (or a junkyard) and pick some up. It's fireproof and all that good stuff.
Jan 3, 2008. 11:53 AM!Andrew_Modder! says:
xD thats awesome!!! when i get a car im gona do this with something lol but il have to weld it down cause someone from my school would probably try to jack it . thats a great instructable!
Jan 3, 2008. 10:55 AMGorillazMiko says:
That's awesome, I love crazy stuff like this. Funny part was the 2nd to last picture. "On the hood." haha.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Emperor Dane
Im a Student at RPI in Troy NY. The best part of college is most definatley 'Spelunking' or dumpster diving for parts in the elctrical engineering dumpster.
