loading
Picture of Adding MP3 to your project for $3.00
As a Propeller microcontroller user, it's not a big deal to play WAV files with my MCU, but MP3 playback is something too complex for the Propeller, the Ardunio or PICAXE microcontrollers.   Shopping for an add-on card is almost downright depressing, with  simple breakout boards starting at $20.00 -- $199.00.
Fortunately, Hong Kong has mastered ultra cheap MP3, and with a little hacking you can add it to your project for around $3.00.
I'll demonstrate the hack using a Propeller, but the best part is that ANY micro-controller can use the device once you've got the project finished.
Required Parts:
A generic MiniClip MP3 player (Source Ebay prices range from $0.26 -- $3.00)
Your favorite microcontroller.  (I'll be using Propeller Platform, but any will do fine.)
A hot glue gun
A steady hand, and basic soldering tools.
Step 1: Teardown
Picture of Teardown
Grab a tiny philips screwdriver and pull the two screws from the top of the Miniclip player.
The whole thing should slid out with a little prying.
Notice the little battery, as well as red/black wires.   The Miniclip runs great a both 3.3v and 5v.
Step 1 > Carefully, desolder and set the battery aside, we'll use part of it later.
ruebarb1 year ago
Thanks for posting this, I would like to add mp3 like you did but without a controller, I only want to toggle the play/pause button. I can't tell from the data sheet what the high and low voltages are, http://elmicro.com/files/parallax/propellerdatasheet-v12.pdf. Do you know or could you measure? Also using a single switch that when on to off to on would produce the same effect as the controller? Thanks for any help
Thanks for this, it works really well.
I want to be able to make the mp3 player totally wireless (through xbee). However, if I use the power of the MP3 player battery (rather than attaching it to an Arduino power) it doesn't work.
My electronics knowledge is still pretty basic...I'm guessing it could be either that a common ground connection is needed or that there's slight voltage difference between the MP3 player and Arduino.
Any ideas on how to fix this..?
Cecilias3 years ago
Se ve muy agradable y sencillo. ¿Se puede utilizar para descargar musica gratis?
Si, para musica de tipo MP3.
mykrotek3 years ago
Thanks for the great idea! I just used it for an upcoming project I am working on, and did a slight tweak on your idea to make the MP3 player more portable between projects. You can check it out at my blog at teknynja.com.
