3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adding 'Oomph' to the Garden Solar Light
Step 4What IS this sh*t???
Making our many legged creature.
Start by holding the 'C' lead of the 2N3906 to the 'B' lead of the FPN965 and soldering them together.
When you have attached the 2 capacitors and the diode to the transistors, this section is done.
Let me emphasize the need to COOL the parts after applying solder. The rule-of-thumb is to blow on the solder for TWICE as long as you apply heat. So if the joint took 2 seconds, cool it for 4 seconds. Heat is the second highest cause of failed circuits. (Number one is operator/designer stupidity.)
A few more images of the process of building our amorphous creature. Fine needle nose pliers are a must-have for little circuits like this. As is a GOOD soldering iron with a 1/16" or 1/32" tip.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
177
Author:qs
