3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adding USB(charging) to iPad VGA adapter
It's my first instructable, and I wanted to share with world what hawe I done this time. Time to time I play with many of things upgrading it's functionality. But with this one I like to share. By the way, sorry if my language is bad, but there, in internet you already are familiar with that, I prefer. So, closer to case, you bought your iPhone4 or iPad, I got my iPhone too, so that's nothing exceptional. You bought VGA adapter, I bought too, and it drains baterry fairly quick. So there it ends, add USB to your VGA adapter, and I wil try to explain how. Sadly I dont hawe all steps with coresponding images, so I will use what I hawe.
What you need:
1. Apple iPad VGA adapter
2. USB cable with one end 4 pin USB A jack connector
3. Soldering iron with small tip
3.1. Hawing flux will help a bit.
3.2. Some tin
4. Knife
5. Pliers?
6. wirecutter
Step 1Opening 30pin connector
Somehow you need to remove inner plastic bezel from 30pin connector side. its glued there, so with some screvdriver, knife or somthing else help you need to open it. If you dont broke it while opening, than when you end it will look as new.
6 comments
Jan 12, 2012. 8:40 PMThorius says:
Works great!
Sep 25, 2011. 1:51 PMcncwanabe says:
how do I make a vga out cable for my ipad I have been looking for a while
Sep 9, 2011. 9:12 PMcentaurboi2 says:
Where can I find pin out information? i.e. Power pins, data pins, audio pins, etc. Thanks, cool instructable!
Sep 25, 2011. 1:44 PMagis68 says:
if already you are owner of any of Ipad, ipod touch or iphone there's specific application named pinout...has all the pinouts forms....if you dont have any of those and you are PC or MAC users just visit....http://pinouts.ru/connector/
and http://pinouts.ru/all/.....its russian site but uses english so its very helpful
Sep 12, 2011. 1:00 PMdenty says:
by using this?
you solder pin this
F-Green-White-Red-F-F-F-Black-F-F-F-F-F-F-F
and the pin usb this
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
for example you solder pin 2 is d+(green) you solder in (green) 2 GND Audio & Video ground (-), internally connected with Pin 1 on iPod motherboard (as the pinout 30 pin connector)
3 Right Line Out - R (+) (Audio output, right channel)
4 Left Line Out - L(+) (Audio output, left channel)
8 Video Out
Composite video output (only when slideshow active on iPod Photo)
or Component Video Pb
thanks
best regards
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ctrlaltdel02
