Introduction: Adding a Light Diffuser
Picture of Adding a Light Diffuser
The following information is a single lesson in a larger project. Find more great projects here.
Return to Previous Lesson: Writing the Code
Lesson Overview:
Now we'll make a simple light diffuser!
Step 1: Adding a Light Diffuser
The LED on its own is pretty neat, but it’s not much of a lamp. However, there are a number of different ways you can diffuse the light to make it resemble something like a traditional incandescent bulb.
A ping pong ball with a hole cut out for the LED to slide into makes for a nice diffuser. Other ways include covering the light in translucent glue, or sanding the surface of the light. No matter what route you take, you’re going to lose a little brightness when it’s diffused, but it will probably look a lot nicer.
  1. Try adding a ping pong ball, or another frosty plastic object, in front of the RGB LED.
  2. What else can you use as a light diffuser?
Congratulations, you have completed this project!
Check out other great projects here.
About This Instructable
243views
1favorite
License:
Bio: Learn electronics and Arduino with Tinkercad Circuits!
More by circuits:Build the Move Circuit AssemblyGlow Circuit Assembly ProjectsBuild the Glow Circuit Assembly
Add instructable to:
