3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adding a line in to a boombox with a tape player
** As with all the instructables, you take your item / health / whatever into your own hands when attempting ! Be mindful of high voltages on the main power board, the hot soldering iron, etc. Being careful and patient will bring you success. **
This is my first instructable, but I've been doing this sort of thing for a long time !
I know about the cassette adapters, but all the ones that I have tried cause too much background noise.
With this in mind, I decided that I wanted to add a line in to an old boombox that has seen better days, but still sounds good.
I found this baby left for dead on a job site, so I took it and cleaned it up (goof off plastic safe formula), fixed the cd lid, and now I want to add a line in so that I can use it with my mp3 player.
The reason is simple. Now I use an FM transmitter, plugged into a cigarette lighter adapter (which is plugged into the wall), and I hook my mp3 player to the FM transmitter (with an adapter from the 3/32" jack to 1/8") and then tune the radio on the boombox to the transmitter's station.
Besides being bulky, it picks up a lot of static and interference.
The white boombox in the picture was going to get the line in install, but after taking it apart I didn't want to chance breaking it to find the signal from the FM board (or even the CD player).
Step 1Disassemble
Disassemble
Sony (and many other brands) makes it easy to take their products apart by stamping an arrow by the screws that you need to remove to get the unit apart.
This boombox is model # CFD-S36
I took out all the screws indicated, and that got the front chunk (which holds the speakers) off.
Then I followed the next set of arrows and the unit split into 2 more parts.
37 comments
Nov 27, 2011. 2:59 AMfdebord says:
Hey, thanks for the tutorial, this is pretty cool. i was thinking of doing that on an old panasonic boombox, and was amazed to find something about such a conversion online...
The thing has both an amplifier and a preamp... Where do you reckon is the best place to hook the cables?
Thanks a lot!
Jan 9, 2010. 5:22 PMeli2k says:
Hey, thanks for the guide. I'm trying to do something similar to a stereo shelf system (tape/CD/tuner). What was the part number for the IC, or can you link directly to the datasheet? The stereo I have is using LC75392 IC chip, the cassette deck uses TA8189N for its preamp, but not sure how to approach this yet. If you soldered the left/right leads to the preamp, where did you solder the ground pin to?
Oct 24, 2011. 9:29 AMlukethedog says:
I see it has been sometime since you put up this instructable. But, I am curious. Did you just put the MP3 output (via the connector) directly to the IC chip ? Or did you still use the imput from the tape head ? It seems like you can bypass that part and just goto the chip.
Thanks for anymore info. Great stuff, thanks for taking the time to put this together. I am sure that took more time then the addition of the (AUX) port.
Oct 11, 2011. 3:44 PMab727 says:
This is a very old instructable and I just hope you would be interested in my comment/problem.
I have an old Philips cassette+radio player. It does not have a line-in but it does have a line-out.
I want to connect my iPod shuffle to it. I don't much care about the radio/tape.
I do not have much knowledge about electronics (bio student)
I opened it up and I found this.
There are three boards - #1, #3 and the board under the cassette player.
Wire #2 connect Board #1 to speakers. Board #1 also has line out.
Board #3 is radio board and has the radio needle and also the volume wheel.
Wire #4 connect the power to Board # 3. Only board #3 has power supply.
Red Blue Wire #5 connect board #3 to Board #1.
So board #1 is connected to speaker and cassette board by wire # 2& #5
Power is connected to Board #3
A lot of other wires connect board #3 and cassette board.
Now. I was wondering if I could just cut Wire #5 and attach it to a cut 3.5mm connector wire could it all work. I don't want the radio/cassette player just the mp3 player.
Please help.
Oct 15, 2011. 10:32 AMab727 says:
I have just posted my instructable. Here is the link
http://www.instructables.com/id/Attaching-a-Line-In-to-an-old-Philips-Radio-Casset/
It would not have been possible without your excellent write up. Thank you.
Oct 18, 2011. 3:57 PMab727 says:
How can I have not mentioned your name. Yours was the one that gave me the whole idea in the first place!
Oct 13, 2011. 4:36 PMab727 says:
Thanks for the reply.
Sadly, I was too impatient and decided to start on my own just a few minutes after writing to you.
When I cut the wire #5 and connected my wire, a strange thing happened. The sound was produced, even without any power source. I guess it was drawing power from the iPod. The sound was clear, not loud but can easily be heard in a room.
There were 2 wire sets connecting board #3 and cassette board. One had 3 and the other had 4 wires.
I cut the set with 3 wires.
When I attached the wires no sound was produced but when I accidently touched a wire to the radio board (#3) there was sound!
Finally, by luck and no knowledge, I got the result.
I am uploading photos for an instructable right now. Shall be posting a link to you as soon as I finish the right up.
I regret that although I did succeed I do not know the reasoning of the thing. So it was all by a random chance.
Thanks for writing the reply.
Best regards
Oct 1, 2010. 2:30 PMxtian5 says:
Can you put a mic into the line in and record with the tape recorder. I just got a similar tape/CD player but it won't record external sound like the old ones. I tried putting a microphone into the headphone jack, but that wouldn't work either. I was thinking of trying to add a line in so I make simple scratch tapes of playing guitar and singing. I could probably go out and find an older boombox for $5 that already has the feature but where's the fun in that.
Sep 20, 2009. 2:59 PMjerkey says:
Great instructable! I have done this myself a few times, and I recommend finding the audio signals coming from the radio or CD circuit. If you are lucky, they will be Red and White for Right and Left. Cut one, and that speaker will go silent - cut the other, and then hook those four wires (two red and two white) to a switching headphone jack from radio shack. Such a jack has five wires - Left in, Right in, Left out, Right out, and Ground. If you are lucky, the red and white wires you cut will reach the place you install the jack. When nothing is plugged in, the CD or radio will function as normal, but when you plug in, the jack automatically disconnects the CD player or radio. You will have to add a wire for ground from the jack to ground on one of the boards, you can usually tell Ground because it is the most prolific trace on the board. keep in mind: if you use the audio wires from the CD player, it might not work unless the CD player thinks it's playing a disc. Same with the tape wires. If you are having trouble finding the Left and Right signals here's a hint: if the boombox has a physical switch to select between Tape and Radio etc, the Left and Right wires are definitely there! Good luck and don't give up until you get it!
Mar 13, 2010. 7:49 AMsoultron says:
Great write up! I see how it works, but it still shows how little experience in this. I'm stuck until I find a schematic, or I guess I could try and hunt out the right leads... My box is much older than yours.
Feb 2, 2010. 2:36 AMsamuraiclinton says:
After reading this, I could easily manipulate a radio to only accept external line-in devices.
I think manufacturers of future ghettoblasters could save money omitting the radio feature.
I could go on for hours explaining why external devices such as MP3 players and other stuff are more beneficial and better for the environment!  But I'm keeping this comment short with that statement since DIY projects can also save the environment as well.  I even made a homemade advert on YouTube to make a point on why to visit Instructables.com
Jul 16, 2009. 4:26 PMbensmith8302 says:
I did the same thing to my Sony jam box. Its very interesting that mine has the same circuit board as yours. Thanks so much for the help!
Apr 13, 2009. 2:29 PMsphynx88 says:
great right up,
just to be sure I am understanding this (ic):
Before the wires were connected Tape Head > Certain Point on circuit board.
Tape Head> Phone Jack> Certain Point = static
Now they go from Tape Head > Phone Jack > IC
right?
Nov 3, 2008. 12:49 PMmaxpower49 says:
could you just cut the wires going to the motor do you need the toggle switch
Sep 27, 2007. 12:49 PMmondaymonkey says:
Good instructable. Me, being lazy, have made the simplest solution to amplifying Ipod ect. Take a old pair of computer speakers, the ones that divive their power from a wall outlet, not a USB. Simple, and not bad sound if you avoid loud volume. If you want bass, this isn't for you:P HEY, I have an old comp and home, half decent, about 933 Mhz processor, and 256 ram (almost as good as the laptop im workin on now) any one got any good ideas how to soundproof so i can listen to music without a hum?
Jun 23, 2007. 1:50 PMwaterppk says:
Hey, I was going to do this but i realized that my boombox has a separate board that sends the radio signal from the tuner (radio) board over to the amplifier/tape deck board. It sends over +/- power to the tuner board and then the tuner board sends back R/L audio. They are labeled exactly as +/R/L/- on a four conductor flat cable that runs between the tuner and the amplifier/ tape deck. I simply cut a stereo headphone cable leaving me with the four wires (red/green/two gold) to solder on to the R/L/- going into the amplifier/tape deck board. [ TIP: if you are ever trying to solder headphone cabling you need to BURN OFF the colored insulation with a lighter. Take the four ends of the internal wire and burn just the tips clean with the lighter, they will then be down to copper and solderable]. If you have questions message or e-mail me at waterppkNOSPAM@NOSPAMgmail.NOSPAM.com.NOSPAM.
Apr 26, 2007. 6:42 PMmdmoose29 says:
i tried doing this same thing a few months back... after i took it apart it wouldnt even turn on again. very strange since i hadnt messed with the wires yet... never did figure that out. But I'm glad to see you had a better go at it than me.
Apr 26, 2007. 7:30 PMleevonk says:
uhm,.. so all one needs is the last step it seems... just solder the audio input wires to the IC right..
Apr 28, 2007. 12:54 AMmarquoise says:
Great instructable, I'm gonna go out and get an old tape player and turn it into an MP3 amplifier. Junk stores are full of decent tape player units. Love the way you documented the project too. Showing us your whole process, problems included, rather than just the end result.
Apr 27, 2007. 2:31 PMPunkguyta says:
What did you do to your boom box? Kick it around?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:TheRealAnubis
I usually end up doing an instructable because I have to figure out how to do something myself. I just get pictures during the process, and if it works out, BOOM, an instructable!
