3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adding a right mouse button to a Macbook
This shows you how to add a right mouse button to a Macbook's trackpad -- click the left side of the existing button, that's left click, click the right and that's right click. Works in Windows, Linux and Leopard.
Step 1Find the electronics
While you don't have to take the top panel out (especially on a Macbook Pro) since you can reach through the battery hole, I find it's easier to do so. If you don't, make sure to disconnect power!
Make sure you have plenty of light to work. This modification requires only a few soldering joints (as few as two) but one of them can be pretty difficult to do, so be sure you can see what you're doing.
Remove the transparent plastic that protects the circuitry; it can go back on later.
24 comments
Jan 31, 2012. 8:00 AMgmichaelt says:
One Finger Snap (" is a Preference Pane that brings up the contextual menu whenever you click and hold down the mouse button. This means that you can do everything with a single-button mouse that you can do with a 2-button mouse." Once installed, and with 'enable access for assistive devices' turned on in the Universal Access system preference and 'tap to click' turned on in Trackpad, a prolonged mouse-down on the trackpad will bring up the contextual menu. Functionally, that's a right-click in your current context (RMB, effectively). You can set the delay before the menu appears i.e. the length of time required of the mouse-down. Generally, you want the delay to be ~.5 seconds, but it's tolerable at ~.75 or even 1.0 seconds. Obviously, this also works with a mouse button--should you ever come across a USB mouse with only a single button (they do exist).
Jan 22, 2009. 7:05 PMjeff-o says:
Hmmm, sharp pictures would really be helpful here.
Jan 31, 2012. 7:51 AMgmichaelt says:
Take the lens from a dead optical drive, judiciously mount it in a convenient holder, and secure that holder to the cell phone, directly over the lens of the phone... There's an instructible showing how that can be done, I believe. Haven't tried it myself--I don't have a cellphone.
Jan 23, 2009. 3:56 AMjeff-o says:
Hmmm, aside from getting a dedicated camera I'm not sure what to suggest. I suppose the photos you have are about as good as it gets for a cell phone camera - they're not so great for macro shots! Vector drawings could help too, though that's a lot of work. I think that one ought to be enough, just to show where everything is. That should help people get aligned, then they can follow the written instructions more easily.
Jan 23, 2009. 7:43 PMKittymew says:
Work kinda never ended today, sorry about that; I'll try to remind her about the vector drawings, we had a rough day.
Jan 22, 2009. 4:32 PMkelseymh says:
System Preferences -> Trackpad -> [X] Secondary Click {Bottom Right Corner}
Jan 22, 2009. 5:21 PMez4u2sa67 says:
i think that only for the new (late 2008) macbooks.
Jan 24, 2009. 6:44 PMdaveismith says:
While this approach may only work on the unibody, I use the System Preferences > Trackpad > For secondary clicks, place two fingers on the trackpad then click the button option on a mid-2007 laptop. It works like a charm, I don't have to try and get my thumb over to the right hand side of the click button. When I'm at work using my windows laptop I find that I miss this feature (even though I've got two buttons). This works in both Mac OS X and Windows (Bootcamp). I don't know if there's an option in a linux driver for this though.
Jan 15, 2011. 11:07 PMcody777 says:
same here
Feb 10, 2011. 5:53 PMwillrandship says:
What a headache for something that should have been included. How could anyone play minecraft on that? :P
Nov 14, 2011. 10:14 PMPSPerson says:
I do it all the time, It isn't too bad once you get used to it. Although, I do prefer my mouse, the trackpad is the most inconspicuous for in-class gaming.
Jan 22, 2009. 9:37 PMkelseymh says:
Okay. Given the posting date, it wasn't obvious that the author was referencing an older model. (Hey, spiritplumber, do you want to add a note in the topic text about which models your solution applies?). Sorry for the confusion.
Jan 22, 2009. 5:48 PMphant0m_sp00f3ra says:
exactly, that only works with a 5,1 "Unibody"
Jan 23, 2009. 9:22 AMphant0m_sp00f3ra says:
yeah your hack do works in all, but the Systtem preferences > trackpad > seconadry click bottom only works in the new buttoneless trackpad
Feb 10, 2011. 5:55 PMwillrandship says:
Doesn't mac have a left handed mouse option? If you reverse the joints, just use that.
Apr 16, 2010. 11:48 AMbidwellian says:
How about making a 3 button mouse?
Jan 26, 2009. 4:47 AMMax Headroom says:
Dude! Buy a decent digicam with macro mode before make a thing like this, please!
Jan 24, 2009. 1:05 PMcflowers says:
Great hack! I featured it on The Daily Hack. Keep hacking, modding and building! :)
Charlie Flowers
DailyHack.net
twitter.com/charlie
Jan 23, 2009. 9:10 AMJonas714 says:
A software workaround is also available for the older MBP's. System Preferences -> Trackpad -> Select 'Tap Trackpad using two fingers for secondary click'. Which essentially means if you rest two fingertips on the trackpad the button triggers a right click, or tapping with two fingers triggers a right click. Is tearing apart your MBP for this really necessary?
Jan 23, 2009. 8:48 AMvcolombo says:
How about the two finger right click in trackpad preferences? Works great for me. In fact I find it easier than trying to hit a secondary trackpad button with my thumb. I take it the author of the instructable didn't like that option for some reason.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:spiritplumber
