WARNING!!! THIS MOD WILL VOID YOUR WARRANTY AND YOUR CONTROLLER CAN BE DAMAGED IN THE PROCESS. I TAKE NO RESPONSIBILITY FOR EITHER OF THESE, NOR AM I RESPONSIBLE FOR YOUR PARENT'S COUCH CUSHIONS. PROCEED AT YOUR OWN RISK.
Side Note: You will have to enable voice to be played out of your tv's speakers. This can be done through preferences in the xbox 360 dashboard.
Tools need:
Dremel or drill with small drill bit
Soldering Iron
Desoldering tool
Solder
Small flat head screw driver
Hot glue gun
razor blade (optional)
Parts needed:
Xbox 360 controller (any type)
Cotton or soft foam (optional, I used toilet paper)
Small Microphone (I used one from an old laptop, but any small mic should work.)
If you can't recycle a microphone from old tech this mic should work fine.
http://www.sparkfun.com/products/8635
Remove these ads by
Signing UpStep 1Disasembly
Once the screws are out pull the top half of the controller off while the buttons are facing the ground. This will prevent the buttons from falling all over the floor. You can tape the buttons down from the top of the controller, but we will be removing them temporarily anyway so I skipped this.
Pull the motherboard out and disconnect the tumble motors.
comment
Add Comment
Add Comment
