Address Book: Valentines Day Special
Published
Introduction: Address Book: Valentines Day Special
This is my address book for windows made in vb 2010 thank you for looking at my instructable
the features are the following:
Save
Open
Merge
Bubble sort
Add
Delete
Edit
the inputs are as follows:
First Name
Last Name
Phone Number
Address
Zip Code
City
State
Hotness Code
Step 1: Form Design
For my form i added the following:
2 listboxes
7 textboxes
4 buttons
1 menustrip with the following items:
File - open, save, and merge
exit
Step 2: Form Properties
select the label, listboxes, textboxes, buttons, and menustrip and change the forecolor to deep pink (valentines special)
change the fonts to the following:
for listbox2:
Bella Donna, 20pt (20pt may show up as 20.2499981pt)
for everthing else:
Bella Donna, 12PT.
for listbox 2 change the following:
collection to the following:
5
6
7
8
9
10
picturebox1 property's:
backcolor: transparent
button1:
text: add
flatstyle: flat
button2:
text: delete
name delete
flatstyle: flat
button3:
text:edit
flatstyle: flat
button4:
text: add edit
flatstyle: flat
Step 3: The Code: Dimensions
double click form1 and add the following dimensions after "Public Class Form1":
Dim c As Integer = 0
Dim i As Integer = 0
Dim sr As Integer = 0
Dim m As Integer
Dim nd As Integer
Dim sd As Integer
Dim j As Integer
Dim g As Boolean = True
Dim a As Boolean
Dim k As Boolean
Dim lk As String
Dim kl As String
Dim row As String
Dim p As String
Dim gf(8, 5000)
Step 4: The Code: Add_click
i made the add button click first so that i would be able to add items before i save my addresses
put the following code after the dimensions
double click the add button and add the following code:
k = False
gf(0, i) = lastn.Text
gf(1, i) = firstn.Text
gf(2, i) = num.Text
gf(3, i) = adrs.Text
gf(4, i) = city.Text
gf(5, i) = st.Text
gf(6, i) = zip.Text
gf(7, i) = hotness.SelectedItem
ListBox1.Items.Add(gf(0, i) & " ~~ " & gf(1, i) & " ~~ " & gf(2, i) & " ~~ " & gf(3, i) & " ~~ " & gf(4, i) & " ~~ " & gf(5, i) & " ~~ " & gf(6, i) & " ~~ " & gf(7, i))
i += 1
sort()
Step 5: The Code: Delete_click
after the add click code add the following code:
Private Sub delete_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles delete.Click
sd = ListBox1.SelectedIndex
For q = sd To i - 2
For l = 0 To 7
gf(l, q) = gf(l, q + 1)
Next
Next
If i > 0 Then i -= 1
ListBox1.Items.Remove(ListBox1.SelectedItem)
End Sub
Step 6: The Code: Edit_click
after the delete_click code add the following:
Private Sub edit_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles edit.Click
svedit.Visible = True
add.Visible = False
delete.Visible = False
edit.Visible = False
lastn.Text = gf(0, sd)
firstn.Text = gf(1, sd)
num.Text = gf(2, sd)
adrs.Text = gf(3, sd)
city.Text = gf(4, sd)
st.Text = gf(5, sd)
zip.Text = gf(6, sd)
hotness.SelectedItem = gf(7, sd)
End Sub
Step 7: The Code: Svedit
after the edit_click code add the following
Private Sub svedit_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles svedit.Click
svedit.Visible = False
add.Visible = True
delete.Visible = True
edit.Visible = True
gf(0, sd) = lastn.Text
gf(1, sd) = firstn.Text
gf(2, sd) = num.Text
gf(3, sd) = adrs.Text
gf(4, sd) = city.Text
gf(5, sd) = st.Text
gf(6, sd) = zip.Text
gf(7, sd) = hotness.SelectedItem
ListBox1.Items(sd) = lastn.Text & " ~~ " & firstn.Text & " ~~ " & num.Text & " ~~ " & adrs.Text & " ~~ " & city.Text & " ~~ " & st.Text & " ~~ " & zip.Text & " ~~ " & hotness.SelectedItem
sort()
End Sub
Step 8: The Code: Save
after the svedit click add the following:
Private Sub SaveToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SaveToolStripMenuItem.Click
SaveFileDialog1.ShowDialog() 'shows savedialog
p = SaveFileDialog1.FileName
Dim objReader As New System.IO.StreamWriter(p)
ad()
objReader.Close() 'closes savedialog
k = True
If k = True Then Label2.Visible = True
sort()
End Sub
Step 9: The Code: Open
after the save code add the following:
Private Sub OpenToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OpenToolStripMenuItem.Click
OpenFileDialog1.Filter = "data|*.txt|all|*.*" 'shows only .txt files
OpenFileDialog1.ShowDialog() 'shows opendialog
p = OpenFileDialog1.FileName
c = 0 'reset c counter to 0
Dim s As New System.IO.StreamReader(p)
Do Until s.EndOfStream
row = s.ReadLine
For l = 0 To 7
gf(l, c) = row.Split(",")(l)
Next
c += 1
Loop
s.Close() 'closes opendialog
ListBox1.Items.Clear()
ad()
sort()
End Sub
Step 10: The Code: Merge
after the open code add: copy the open code and past it for the merge tool strip item and delete "c=0" and change the c += 1 to i += 1
Step 11: The Code: Suberteens and Exit
at the end just before "end class" add the following:
Private Sub sort()
g = True
Do Until g = False
g = False
For y = 0 To i - 2
If UCase(gf(0, y)) > UCase(gf(0, y + 1)) Then
g = True
For x = 0 To 7
kl = gf(x, y)
gf(x, y) = gf(x, y + 1)
gf(x, y + 1) = kl
Next
End If
Next
Loop
For nm = 0 To i - 1
ListBox1.Items.Add(gf(0, nm) & " ~~ " & gf(1, nm) & " ~~ " & gf(2, nm) & " ~~ " & gf(3, nm) & " ~~ " & gf(4, nm) & " ~~ " & gf(5, nm) & " ~~ " & gf(6, nm) & " ~~ " & gf(7, nm))
Next
End Sub
Private Sub ad()
For r = 0 To i - 1
ListBox1.Items.Add(gf(0, r) & " ~~ " & gf(1, r) & " ~~ " & gf(2, r) & " ~~ " & gf(3, r) & " ~~ " & gf(4, r) & " ~~ " & gf(5, r) & " ~~ " & gf(6, r) & " ~~ " & gf(7, r)) 'add array items into listbox1
Next
End Sub
Private Sub ExitToolStripMenuItem1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitToolStripMenuItem1.Click
If k = False Then a = (MsgBox("Are you sure you want to exit", vbYesNo) - 6) Else End
If a = False Then End
End Sub
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
