For more on Adirondack Chairs, see our original story.
Our version of the Adirondack chair has come a long way from the early types that had flat backs and seats-and, we've added a matching table. Don't be intimidated by the curved slats and number of pieces in this project. Although there are a few angles and curves to cut, there's actually no fancy joinery --everything's held together with deck screws. We used cedar for these pieces because it stands up well to the elements, and it's available in the required 3/4- and 1-in. thicknesses. You could substitute pine if you plan to keep the chairs out of the weather.
Remove these ads by
Signing UpStep 1Plans and Materials
A. 2 1 x 5 1/4 x 33 3/4" cedar side rail
B. 1 1 x 4 1/4 x 23 1/4" cedar top back rail
C. 1 1 x 3 1/2 x 23 1/4" cedar bottom back rail
D. 9 3/4 x 2 1/4 x 23 1/4" cedar seat slat
E. 7 3/4 x 3 1/4 x 35 1/2" cedar back slat
F. 2 1 x 4 1/4 x 20 1/2 cedar front leg
G. 2 1 x 2 1/2 x 29" cedar back leg
H. 2 1 x 2 3/4 x 6 1/2" cedar arm bracket
I. 2 1 x 5 1/4 x 28" cedar arm
J. 2 1 x 5 1/4 x 16" cedar foot
K. 2 1 x 1 1/2 x 19 1/4" cedar cleat
L. 2 1 x 5 x 16 1/2" cedar leg
M. 2 3/4 x 5 x 17 1/2" cedar stretcher
N. 5 1 x 3 3/4 x 24" cedar slat
O. as required 1 5/8" No. 8 fh deck screw
P. as required 2" No. 8 fh deck screw
http://www.popularmechanics.com/home_journal/woodworking/2919751.html
Here is a site with some authoritative information about the differences.
Woodmill is a company that makes this type of chair.
Muskoka
1. Origin to the Muskokas
2. Seat lower to ground, comfort fit
3. 19" span between arms
4. Longer seat front to back
Adirondack
1. Origin to the American Adirondack Mountains
2. Seat higher off ground
3. 21-1/2" span between arms
4. 1-1/2" legs
And, there you have it.
http://www.popularmechanics.com/home_journal/workshop/2919751.html?series=20
Sorry to take so long. You can still make the adirondack set in time to set it all up for summer!
instead of:
http://media.popularmechanics.com/documents/adirondack-html.pdf
However, this pdf is only 3d picture and it doesn't help a lot with the invisible sizes... The plans with the measurements are not readable and are needed for this project.
