Introduction: Adjustable Led
Picture of Adjustable Led
I recommend you not to use this kind of pcb
Step 1: Led
Picture of Led
Put the led some where on the board. Then bend the leads.
Step 2: Attach
Picture of Attach
Then attach the pcb to a holder or vise.
Step 3: Solder the Leads
Picture of Solder the Leads
Step 4: Cut!
Picture of Cut!
Cut the leads and remember the negative and positive leads.
Step 5: More Soldering
Picture of More Soldering
Solder one lead to the led from a battery back max 6. Depending on led.
Step 6:
Picture of
Next take the middle lead of the potentiometer and solder it to the negative lead of the led
Step 7: FINALY
Picture of FINALY
Finally' solder one pin of the potentiometer to the other wire of the battery pack the add protection to the soldered wire.
Step 8:
Put in batteries and test
bhvm (author)2014-01-10
what grade/value potentiometer shall be used? and yes, you could take some inspiration from some of the really nicely written instructables out there!
minecraftpotato (author)bhvm2014-01-10
well i used a 500 ohm potentiometer
domints (author)minecraftpotato2014-01-10
So you should write this in instructable.
About This Instructable
1,606views
14favorites
License:
More by minecraftpotato:Adjustable LedGame Boy On IpodGame Boy Games On Ipod
Add instructable to:
