3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adjustable Modular Furniture
This is a piece of furniture that can be bent like a snake and is screwed solid with nuts. You can create lots of different tables and chairs. I will make 8 sections but you can choose to make as many sections as you want. You can always add sections later.
Step 1Materials to make 8 sections
  • 32 - 1 foot sections of 2x4
  • 9 - 15" sections of threaded rod ( I used 5/16" rod )
  • 18 - grade 8 nuts (size of rod)
  • 100 - 1 1/4" outer size fender washers (size of rod)
  • 300 in2 - 60gt sandpaper
  • Wood Stain
  • Glue
55 comments
1-40 of 55next »
Nov 26, 2011. 5:14 PMhbueso says:
This is actually an excellent idea. And it also gives you inspiration to create more variations of this, hmmm!!
Jul 31, 2011. 1:24 AMtdawber-mandeno says:
its not hex its a octogon
May 20, 2011. 8:00 PMgamemasterful says:
Might try this idea with cardboard instead of lumber.
May 18, 2011. 7:07 AMpleszmc says:
if you were making a box or a chair or a table with this, how would i support its self? it looks like it would sag at the bend points (not the corners, the're fine)
Mar 16, 2011. 1:29 AMfspatz says:
really great idea! i think IKEA (swedish furniture factory) will copy this ;-)
Jun 21, 2009. 9:03 AMDerin says:
By grade 8,do you mean M8 nuts?
Jan 28, 2011. 3:47 AMgossumx says:
http://www.boltdepot.com/fastener-information/materials-and-grades/bolt-grade-chart.aspx
Jun 27, 2010. 7:34 PMApple_4_life says:
ok, now THAT is effing amazing
Jun 13, 2009. 2:33 PMshabagana says:
This is awesome!! 5 stars
Jul 13, 2009. 2:44 PMPyr0technician says:
Yeah, and IMO it looks nice enough to sit in the house as well, like he has it in his room. Great idea!
Jul 1, 2009. 4:53 PMfrazeeg says:
A chisel would probably be faster and give you more accurate results. A nice sharp blade would cut through that pine like butter without over-rounding the right angle there.
Jun 24, 2009. 9:23 AMdunnos says:
i like it :) but me not have the patience for it
Jun 22, 2009. 5:40 PMafatflatcat says:
This idea actually has potential. Show it to like Ikea or some lawn furniture place. Youll be rich in like a week.
Jun 20, 2009. 7:28 AMcamp6ell says:
i love the technique for making the sandpaper washers. i can see that being parlayed into other things. thanks.
Jun 17, 2009. 9:47 PMPkranger88 says:
So are you actually using it as modular furniture or as a conversational starter? Also, to avoid the issue with the nuts, you could recess the nuts using a forstner bit. Also, you don't need grade 8 nuts. You bought standard threaded rod, right? I believe that stuff is only grade 3 or grade 5 at best if you got it from a box store like Lowe's or Home Depot. I think the ingenuity is great though. It would be cool if you incorporated a cross member with preset holes in it that would align the furniture for different positions enabling "quick change" style adjustments. Good luck.
Jun 18, 2009. 11:07 PMsoapbox derby car says:
is it too much to ask for both? why not sit on it and then talk about it? -the best DIY functions for a purpose, but also is intriguing to talk about, would you agree?
Jun 19, 2009. 6:04 AMPkranger88 says:
Nope, I was just asking. I was hoping he was actually using it. As for the best DIY... I would say function, reliability and servicability are the 3 most important aspects of any design. Then we can get into "intriguing to talk about." But I'm a design guy. But I can say I agree.
Jun 19, 2009. 12:14 AMKristell says:
no..if you had this in you dorm room..i wouldve taken it for myself =P
Jun 18, 2009. 6:35 PMbaggot says:
The weak link is the threaded rod. it will snap before the threads will strip. Unless you cross threaded ;-). Nice chair I would use something along the lines of a quick release setup from a bike wheel to tighten the diff positions. Nice
Jun 19, 2009. 6:00 AMPkranger88 says:
Correct, the weak link is the threaded rod, which is much more expensive than the nut. Another (stronger) option would be to use solid rod and use a die, preferably a roll form die, rather than a cutting die to create the threads. Then you can buy just about any grade of steel you want. I would probably go with a stainless rod. Cross section area of the rod is the critical part. A 5/16th rod has a minor cross section diameter of about 0.24 in. If you were to use a solid 5/16 rod you get the full .3125. Does is really matter? Yep. The solid rod can withstand 69% more shear force and axial load. Which means that if a 200 lb person would bend the 5/16th threaded rod, it would take a 337 pounder to bend the solid rod. I personally have had many experiences where a threaded rod bent and even broke.
Jun 13, 2009. 12:40 PMsallost says:
I love this idea. This summer I'm going to try this for sure! Just 1 question: How long do you thing the sandpaper washers hold until you need to replace then. Thanks
Jun 18, 2009. 9:22 AMarashiodori says:
Perhaps you could use soft washers, and use the nuts to 'squeeze' the construct in place when the desired position is achieved? Should last longer. ;P
Jun 19, 2009. 12:33 AMarashiodori says:
Well, I tried it in the past with my DnT(Aka Workshop period) project, and I cracked the 2 'main' wood (Resembles White Oak visually, forgot the actual species) itself (The wood was slightly thinner than the ones you used) while testing for the structure. Worthless experiment yes, since I had to use a clamp to actually gather enough force to break it, but the wood was free. :P So yes, Rubber washers take quite some punishment.
Jun 18, 2009. 4:02 PMblckpythn says:
the "hex" has 8 sides...
Jun 18, 2009. 6:26 PMTape-structable says:
Should be an octagon. ;P
Jun 18, 2009. 8:37 PMCrucio says:
Fantastic result. What color stain is that?
Jun 14, 2009. 10:56 AMimrobot says:
will this work with your cardboard lumber? and how do i keep the cardboard from rotting outside?
Jun 14, 2009. 2:24 AMKristell says:
how much does it cost for all the materials? ..and of course i get to use your new shop smith :D
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
115
Author:theRIAA
