Remove these ads by
Signing UpStep 1Cut Pipe and Obtain Fittings
For our project we choose to make a unit that would adjust from 4' 6" to 8' so our pipe lengths were as follows. The lengths you choose can change as long as you keep the proportions the same.:
(3) 4' 3-1/2" (Schedule 40 1-1/4" Aluminum Pipe) - Bottom Vertical Pipe
(3) 4' 3-1/2" (Schedule 40 1" Aluminum Pipe) - Upper Vertical Pipe
The triangle pipe lengths are:
(3) 2'-3/4" (Schedule 40 1-1/4" Aluminum Pipe) - Bottom Triangle Pipe
(3) 2'-3/4" (Schedule 40 1" Aluminum Pipe) - Upper Triangle Pipe
NOTE: To save money on the pipe round the lenghts to the nearest foot or use another standard length cut.
Fittings:
(3) LC50-6 Single Swivel Socket, 1"
(3) LC50-7 Single Swivel Socket, 1-1/4"
(3) L15-6 90 Degree Elbow, 1"
(3) L15-7 90 Degree Elbow, 1-1/4"
(3) L70-7 Rail Support, 1-1/4"
(3) 75-6 Collar, 1"
Where to get it:
You can get schedule 40 aluminum pipe through most pipe stores (you won't find it at The Home Depot). If you cannot find it locally you can order it through our site.
You can get the fittings from a Kee Klamp Distributor. That's what we do online: www.simplifiedbuilding.com
Electrical conduit does not generally fit well with our fitting sizes. If you check the OD of your conduit you can see which fitting might work by looking at this chart. Fence Post works well with our size 7 fitting if you're looking for a cheaper way to make something. Also, if you use an alternative pipe I don't know that you'll be able to create the telescoping action that you see on this design.
Hope this helps.
If you bought the fittings from our site they would cost you about $170.00. You can get the pipe from a local pipe distributor (probably another $100 for the brushed stuff in the picture) The way you could save some money on the pipe is to use standard lengths (instead of custom cuts). I would do the verticals at 4ft each an the triangles at 2ft each.
