3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adjustable Solar car panel holder (D.I.Y)
The angle of the solar panel is important inorder to absorb the most energy.
To buy a custom make one will cost a bomb, but here is one easy way to make it with card board, a bolt & 3 nuts.
Step 1Determine the dimension
1- Measure the height of the stand base on the longest edge of the solar panel.
*Measure so that the stand is in the middle of the panel.
2- HALF cut the bending edge...Do NOT cut through, it is meant to bend.
3- Tape along the HALF cut area so as to prevent further tearing.
4- Measure the location of the hole for the bolt to go through.
5- Use a hole puncher to make the 2 holes (for M6 Bolt)
4 comments
Sep 8, 2008. 4:40 AMmackamitsu says:
If you can do that with cardboard you can do that with sheet metal. Very nice and clean, and well thought out.
Dec 7, 2007. 12:09 AMalxram says:
Wow... nice photos and clear instructions. This design is so simple and sturdy looking. Impressive!
Aug 8, 2006. 3:36 AMWonderground says:
Add some motors, a photo sensor to this and that crazy simple curcuit that was used in the electronic sunflower and you could make this rotate to follow the sun on its own easy as pie. I reckon the panel poining to the sun would give more energy then it would without rotation, even with the added powering of the motors.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dodo
