Adjustable Tealight Bunsen Burner Tripod With Optional Flask Holder
4,462
106
7
Posted in HomeEducation
Introduction: Adjustable Tealight Bunsen Burner Tripod With Optional Flask Holder
As a homeschool family, we often perform chemistry experiments. A traditional laboratory style gas Bunsen Burner is not always available or convenient. Alcohol burners are an option, but we never seem to have the alcohol on hand. Often a simple tea light is sufficient.
Additionally, children are not cautious creatures. Glass equipment slides easily off of the tripod platform creating dangerous situations..
This project will simplify your home chemistry lab and alleviate (at least a little) anxiety so you can enjoy performing experiments with your little mad scientists.
Step 1: Gather Your Materials
Materials Needed For Adjustable Tealight Holder:
tripod stand
metal jar lid - slightly larger than tripod platform
marker
drill with bit slightly larger than tripod legs
cable ties
side cutters or scissors
Materials Needed For Optional Flask Holder:
metal jar lid - large enough to hold your largest flask/beaker
drill and drill bit
side cutters or tin snips
pliers
Bunsen burner gauze
Step 2: Disassmble Tripod and Mark the Holes
Remove the legs from the tripod platform. Lay the platform on top of the lid. Trace around the threaded holes.
Step 3: Drill the Holes for the Legs
Drill holes directly through the center of each of the traced circles made in the previous step.
Step 4: Slide the Legs Through the Holes
Slide each tripod leg through the holes drilled in the previous step.
Step 5: Reassemble the Tripod
Screw the legs back onto the tripod platform.
Step 6: Attach a Cable Tie on Each Leg
Attach a cable tie around each leg. The ties need to be snug, but not immobile. We want them to hold the tealight platform in place, but still have the ability to slide up or down. Cut the excess cable tie with a scissors or side cutters.
Step 7: Your Tripod Is Now Ready to Use
The tripod is now ready to use. To increase heat, move the tealight platform and cable ties up. To reduce the heat, move the tealight platform and cable ties down.
Step 8: Optional Flask Holder - Mark and Drill Center
Choose a lid that will be large enough for your largest flask/beaker. Trace the center of the tripod platform onto the center of the lid. Drill a hole in the center.
Step 9: Optional Flask Holder - Cut With Side Cutters
Use a side cutters or tin snips to make several cuts from the middle hole to edge of the mark we made in step 8. Caution: Edges will be very sharp.
Step 10: Optional Flask Holder - Bend Segments Down
Bend the segments down using a side cutters or pliers.
Step 11: Optional Flask Holder - Secure Onto Tripod Platform
Place the the lid (our flask holder), bottom side up. Tip the tripod platform upside down and carefully set it on the flask holder. The segments of the flask holder should now be sticking up through the hole in the center of the tripod platform. Use a pliers to push the segments, flush, against the tripod platform. This will secure the flask holder.
Step 12: Optional Flask Holder - Cut Screen and Insert
Cut a medium weight screen or Bunsen burner gauze and lay it in the flask holder.
Step 13: Your Adjustable Tealight Bunsen Burner With Flask Holder Is Complete
Your adjustable tealight Bunsen burner with flask holder is now ready to use.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    7 Comments
    Nice! Great to see people doing experiments at home. Given that tripods are high mostly to accommodate the height of a bunsen burner, you could always just replace the legs with short bolts (long enough to get the right clearance for the tea light) with the appropriate thread. You should get improved stability out of the lower tripod.
    And you would be able to boil things with this and not just heat them?
    This is a nice solution to a problem common for home-schoolers.
    (If you need the higher temperatures of a Bunsen, then an ordinary DIY/decorator's butane blowtorch should do the trick.)
    This is quite a good solution to a problem, very good. However, in the first paragraph you have put that it will elevate anxiety, I assume you meant alleviate it.
