3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adjustable Vesa Arm Laptop Stand
Step 4Glue, attach.
Glue, attach.
  • Picture 1 - Attach the screw holes off the monitor into the vesa mount just by them selves, now place your drilled piece of wood onto the screw holes to ensure it all works.
If it works, well done! If not, i suggest trying to make the holes bigger and using more glue!
  • Pictures 2,3 & 4 - Glue the screw holes into place using epoxy resin - both super glue, and pva do not work! Place masking tape on the other side to stop the epoxy running out.
Masking tape works best, as epoxy can remain tacky due to residue left by other tapes.
  • Picture 4 - I also added a couple of sections of card inbetween the board and the mount
This is because the length of the vesa screws are designed to be further away (think of that extra layer of plastic on the monitor) and gives it all a more snug fit!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
589
Author:gmjhowe(gmjhowe graphic design)
I am a British Graphic Designer, when I am not working I spend my time making an array of projects, from electronic instruments and chessboards to cyberpunk rifles and steampunk props. If you have an...
more »
