Adjustable Voltage Regulator 317T
Published
Introduction: Adjustable Voltage Regulator 317T
About: Currently am studying in CSE...interested in A.I. and robotics...
Adjustable Voltage Regulator With LM317T
Step 1: Testing in Breadboard
Parts List:
1) LM317T
2) 10uF
3) 0.1uF
4) 240 ohm
5) 50k variable resistor
6) Socket
Tools :
1) Solder Iron
2) Solder Paste
3) Rojon
Step 2: Circuit Diagram
Now put your LM317T on your breadboard pin 1 is adjustable voltage, pin 2 output voltage pin 3 is input voltage positive part of the 10uF capasitor should be connected with pin 1 and a 0.1uF capasitor will be connected with pin 3. The positive part of the 0.1uF capasitor should be connected with pin3. and rest of the pin of capasitor is ground. 220 ohm resistor is connected between ground and pin 2. Wiper pin of variable resistor should be connected to pin 1.
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    How much volts for the input please? Can it be used with 12v in?
