Adjustable Wooden Lamp
Introduction: Adjustable Wooden Lamp
Adjustable table lamp made from scrap wood and christmas ornament.
Step 1: Materials
You will need the following materials:
Scrap plywood and wood blocks
Christmas ornament
Cord with plug
Lightbulb (preferably LED)
Step 2: Lamp Body
On a plywood, measure and draw:
Nine 1" by 4" rectangles
Two 2" by 5" rectangles
One 5" by 5" rectangle
Using a saw or another wood tool, cut out the rectangles.
Using wood glue, attach the rectangles together as shown in the picture.
Step 3: Lamp Base
On a 1 1/2" or thicker wood block draw and measure:
7" by 1 1/2" rectangle
Three 1 1/2" by 1 1/2" square
Cut out the rectangle and squares.
Using wood glue, attach the rectangle and square together as shown in the photo.
As Cut out three rectangles across the center of the wood base according to the thickness of the lamp body.
Drill three holes in each of the section, and create keys on the bottom of the lamp body.
Step 4: Lamp Shade
Cut out a circle on one side of the Christmas ornament.
Measure the diameter of your socket, and cut out a circle on the other of the ornament according to the diameter of your socket.
2" by 4" rectangle
2 1/2" by 1 1/2" rectangle
4" by 1/2" rectangle
2" by 1/2" rectangle
Drill a hole (diameter of your socket) in the center of the 2" by 4" rectangle.
Using wood glue, attach the pieces together as shown in the photo.
Using hot glue, attach the christmas ornament and bulb socket on each side of the wood piece as shown in the photo.
Step 5: Connecting the Wires
Connect the wire set to the socket
How to wire:
Unscrew the gold and the silver screw from the socket.
Wrap one end of the wire to the gold screw and the other wire to the silver screw.
Screw in the two ends back into its original place.
Step 6: Adjustable Lamp
Now, you have a table lamp that you can adjust the height and angle of the light.
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
