Adjustable Drum Stick Holder.
Introduction: Adjustable Drum Stick Holder.
The crowd is screaming for more, in your head you are Keith Moon then out of your sweaty mits the drum stick falls and you end up looking like Rick Allen. What you need is a fully adjustable stick holder.  Lucky you here is one I  made from bits lying around my shed,
you will need:
Cardboard tube (Aluminium or cling film tubes are ideal)
Rear reflector off a bike.
Plastic clip hangers for trousers or skirts.
Old bike inner tube.
Drill bit.
Nut and bolt.
Step 1: Cut to Size.
Get your empty  tube and put a drum stick in it, you will need to have enough of the stick showing  to be able to grab comfortably and don't forget that it will also need a plug in the bottom to stop it falling out. Cut some of the inner tube, just enough to roll up and plug the bottom then tape it closed.
Step 2: Get the Hacksaw Out.
Get hacksawing that coat hanger and detach those clips.
Step 3: Cannibalise That Reflector.
Remove the reflector from the bracket (and put aside for another instructable). Next drill a hole the size of your bolt in the clip as shown
Step 4: Start Putting It Together.
Fit the bolt from the inside of the clip and attach the reflector holder part, tighten but not too much it needs to be able to swivel.
Step 5: More Assembly.
Now you need to attach the clamp part which attached to the seat to the cardboard tube, using some of the inner tube to ensure a nice tight fit. Next attach the clip to the bracket as shown in the photo.
Step 6: Attach That Tube.
Find an appropriate spot to attach the clamp to your kit, you can adjust the hight of the tube and the angle so next time a drumstick goes flying another one will be in easy reach, without missing a beat.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Cool! We used to make these out of pringles cans back in the day.
    Works perfect and love ot
    What a great idea! I'll be making this as a gift for my boyfriend
    Thanks, this is my first instructable. Thanks again for the comment.
