Adjustable Lamp
429
5
Posted
Introduction: Adjustable Lamp
This instructable will show you how to build an adjustable lamp that adjust how many leds that will be lit depending on how close or far away you choose to hold your hand above the sensor.
Remove your hand when you´ve decided how many leds you want to be lit. The leds will remain lit untill you eather move your hand above the sensor and change the range, or if you turn the ON/OFF switch OFF. Then as you might guess the leds will be off and also the sensor.
Step 1: Parts You Will Need
You will need a HC-SR04 sensor, 8 ledpins, 8 220 ohms resistance, a on/off switch or button and last but not least some wires.
Step 2: Building the Ciruit
Build the lamp according to the pictures.
Then intergrade the components into a simple plexiglas module or something nice visually.
Step 3: The Code
#define
trigPin 12
#define echoPin 13
#define led 8
#define led2 7
#define led3 6
#define led4 5 // defining all the leds
int state = 1;
boolean onOff = false;
void setup() {
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(9,INPUT_PULLUP); // defining the leds as outputs
int threshold = 1000;
void loop() {
if (digitalRead(9) == HIGH){ //if the switch is on
onOff = true; // give the variable onOff the value true
Serial.println("HIGH"); //check if is it working in SerialPrint
else if (digitalRead(9) == LOW){ // if the switch is off
onOff = false; // give the variable onOff the value false
Serial.println("LOW"); //check if is it working in SerialPrint
if (onOff == true){ // if onOff is true, the leds will be effected by the motionsensor
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Serial.println(distance); // if distance is closer than 10 cm, all the leds will shine
if (distance < 10) {
digitalWrite(led,HIGH);
digitalWrite(led2,HIGH);
digitalWrite(led3,HIGH);
digitalWrite(led4,HIGH);
else if(distance < 15) { // if distance is closer than 15 cm, all the leds will shine
digitalWrite(led4,LOW);
else if(distance < 20) { // if distance is closer than 20 cm, all the leds will shine
digitalWrite(led3,LOW);
else if(distance < 30) { // if distance is closer than 30 cm, all the leds will shine
digitalWrite(led2,LOW);
else if (onOff == false){ // if onOff is false, the LEDS are turned LOW
digitalWrite(led,LOW);
  • LED Contest 2017
    LED Contest 2017
  • Raspberry Pi Contest 2017
  • Voice Activated Challenge
Questions & Answers
